[Ovmsdev] Smart ED question
Mon Oct 28 11:09:43 HKT 2019
There is a question that came in to support, regarding Smart ED. Can someone with experience of that car have a look, and help answer?
https://www.openvehicles.com/node/2335 <https://www.openvehicles.com/node/2335>
Battery display in the App
I have the smart ED 451. It has a 18 KWh battery and charges very slowly with max 3,7 KW. The display of the battery In the OVMS app is not quite right.
- In the green to the left it says 8 KWh. I assume this is the used power from full. So it should be on the other side, as the green area with 70% represents around 13 KWh of power remaining. However, the numbers don’t add up.
- to recharge fully I will need over 1 hr. But the app only estimates 16 mins. How can I change that?
Thanks, Mark.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191028/8bc289c3/attachment.html>
