[Ovmsdev] SSH Access
Mon Oct 28 01:45:42 HKT 2019
Jaunius,
I don't see your explanation… that note just tells you you can ssh via GSM into the module if your data plan supports it, which has btw been done successfully
by some users and is considered useful.
If you have correctly put your public key into the config store as documented, maybe you've missed the cipher deprecation issue.
You need to add a host entry to your ~/.ssh/config like this:
> cat ~/.ssh/config
Host dexze85.local
Ciphers +aes128-cbc
Am 27.10.19 um 18:38 schrieb Jaunius Kapkan:
> Okay, this explains it :)
> https://raw.githubusercontent.com/openvehicles/Open-Vehicle-Monitoring-System-3/master/vehicle/OVMS.V3/knownissues.txt
> * SSH, TELNET, and WEBSERVER all register listeners for incoming calls. There
> is a possible security issue here as those calls may come over cellular
> networks (not just wifi). There is no firewalling of these calls. It seems
> that the correct approach to this is to validate the destination IP to
> make sure it is a wifi interface IP address; but this is not currently
> done.
> *Sent:* Sunday, October 27, 2019 at 7:33 PM
> *From:* "Jaunius Kapkan" <jaunius at gmx.com>
> *To:* ovmsdev at lists.openvehicles.com
> *Subject:* [Ovmsdev] SSH Access
> Hi,
> I have been strugling getting SSH working for some time now. Tried both password access and key auth. I think the same issue was discussed before for V3, but
> I have not seen the final rezolution.
> Verbose output from client side:
> debug1: Local version string SSH-2.0-OpenSSH_7.6p1 Ubuntu-4ubuntu0.3
> debug1: Remote protocol version 2.0, remote software version wolfSSHv1.1.0
> debug1: no match: wolfSSHv1.1.0
> debug1: Authenticating to 192.168.0.157:22 as 'ovms'
> debug1: SSH2_MSG_KEXINIT sent
> Connection closed by 192.168.0.157 port 22
> Jaunius
> _______________________________________________ OvmsDev mailing list OvmsDev at lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191027/6f9b1019/attachment.html>
