[Ovmsdev] Developer environment
Peter Lord
plord12 at gmail.com
Sun Oct 27 05:47:07 HKT 2019
> On 26 Oct 2019, at 19:57, Tamás Kovács <kommykt at gmail.com> wrote:
> I get a new computer with macOS Catalina. Now I want't to install the developer environment. I use the following commands:
> - sudo easy_install pip
> - download : https://dl.espressif.com/dl/xtensa-esp32-elf-osx-1.22.0-80-g6c4433a-5.2.0.tar.gz <https://dl.espressif.com/dl/xtensa-esp32-elf-osx-1.22.0-80-g6c4433a-5.2.0.tar.gz>
> - mkdir -p ~/esp
> - cd ~/esp
> - tar -xzf ~/Downloads/xtensa-esp32-elf-osx-1.22.0-80-g6c4433a-5.2.0.tar.gz
> - add this: “export PATH=$HOME/esp/xtensa-esp32-elf/bin:$PATH” to ~/.profile without quotes ””
> <>Git clone the OVMS ESP IDF repository:
> <>- git clone https://github.com/openvehicles/esp-idf.git <https://github.com/openvehicles/esp-idf.git>
> - cd esp-idf
> - git submodule update --init –recursive
> -add this: “export IDF_PATH=~/esp/esp-idf” to ~/.profile without quotes ””
> <>Git clone the OVMS v3 repository and init the build configuration:
> - git clone https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3.git <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3.git>
> - cd Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3
> - git submodule update --init --recursive
> - cp support/sdkconfig.default.hw31 sdkconfig
> - make menuconfig
> If I run the make app command I get the following error:
> make app
> Toolchain path: /Users/kommykt/esp/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
> Toolchain version: crosstool-ng-1.22.0-80-g6c4433a
> Compiler version: 5.2.0
> App "ovms3" version: 3.2.005-81-g00ab9db0
> Generating esp32.project.ld
> Traceback (most recent call last):
> File "/Users/kommykt/esp/esp-idf/tools/ldgen/ldgen.py", line 113, in <module>
> main()
> File "/Users/kommykt/esp/esp-idf/tools/ldgen/ldgen.py", line 88, in main
> sections_infos.add_sections_info(sections_info_file_obj)
> File "/Users/kommykt/esp/esp-idf/tools/ldgen/generation.py", line 618, in add_sections_info
> raise ParseException("File " + sections_info_file.name <http://sections_info_file.name/> + " is not a valid sections info file. " + p.message)
> pyparsing.ParseException: File /Users/kommykt/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/app_trace/libapp_trace.a.sections_info is not a valid sections info file. (at char 0), (line:1, col:1)
> make: *** [/Users/kommykt/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/esp32/esp32.project.ld] Error 1
As it happens I've been trying the same on my mac (10.15). I created a little install script and a seperate environment script.
dev.sh :
#!/bin/sh
# sudo easy_install pip
# pip install --user pyserial
# brew install ccache cmake ninja
# /System/Library/Frameworks/Python.framework/Versions/2.7/Resources/Python.app/Contents/MacOS/Python -m pip install --user -r /Users/plord/src/ovms/esp/esp-idf/requirements.txt
set -e
XTENSA=xtensa-esp32-elf-osx-1.22.0-80-g6c4433a-5.2.0.tar.gz
if [ ! -d esp ]
then
if [ ! -f ${XTENSA} ]
then
wget https://dl.espressif.com/dl/${XTENSA}
fi
mkdir esp
cd esp
tar -xzf ../${XTENSA}
cd esp-idf
cd ../..
fi
. env.sh
if [ ! -d Open-Vehicle-Monitoring-System-3 ]
then
else
git pull
fi
cd vehicle/OVMS.V3
make menuconfig
make app
env.sh :
PATH=$(pwd)/esp/xtensa-esp32-elf/bin:$PATH
export PATH
IDF_PATH=$(pwd)/esp//esp-idf
export IDF_PATH
Build completed
I didn't see any obvious difference to what you ran.
Pete
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191026/c3377a41/attachment-0001.html>
