[Ovmsdev] SIMCOM UART FIFO overflows (was Kona electric and http routing)
Thu Oct 24 02:53:43 HKT 2019
For comparison, this is my bench module with the old CP2102:
OVMS# simcom status debug
Network Registration: RegisteredRoaming
Provider: Vodafone.de Hologram
Signal: -91 dBm
State: NetMode
Ticker: 593
User Data: 0
HW FIFO overflows: 63
Buffer overflows: 0
Mux
Status: up
Open Channels: 4
Framing Errors: 61
Last RX frame: 0 sec(s) ago
RX frames: 1069
TX frames: 47
PPP: Connected on channel: #2
GPS: Connected on channel: #1
Status: enabled
Time: enabled
The bench module has both my main Wifi AP and the repeater in reach, so that may also be due to the Wifi situation.
Am 23.10.19 um 19:31 schrieb Michael Balzer:
> I've pushed my SIMCOM changes. With these optimizations, fifo overflows and frame errors have dropped significantly:
> OVMS# sim stat de
> Network Registration: RegisteredHome
> Provider: congstar
> Signal: -97 dBm
> State: NetMode
> Ticker: 73099
> User Data: 0
> HW FIFO overflows: 21
> Buffer overflows: 0
> Mux
> Status: up
> Open Channels: 4
> Framing Errors: 24
> Last RX frame: 1 sec(s) ago
> RX frames: 151452
> TX frames: 5472
> Status: enabled
> Time: enabled
> …but the overflow frequency differs between my modules (both v3.1, the one with the first gen CP2102 has more overflows), and I can still see a direct
> relation to Wifi.
> With Wifi switched completely off, no overflows occurred over a period of ~5 hours. As soon as Wifi was reactivated (regardless of the mode), the errors were
> back.
> Am 23.10.19 um 09:31 schrieb Mark Webb-Johnson:
>> While there is flow control on the USB side, I don’t think there is any between the ESP32 and the CP2102. See Espressif’s example DEVKIT-C schematic:
>> https://dl.espressif.com/dl/schematics/ESP32-Core-Board-V2_sch.pdf
>> or the OVMS one (which we based on DEVKIT-C). Just RX and TX data lines to the ESP32.
> What about the RTS/CTS lines connected to IO13 & IO15 in the core board?
>> However, during flashing there is pretty much nothing else running on the system and no high level operating system.
> Indeed.
>> The good news is that these are very very short data lines. Just a few inches, I think. I did look at the signals in the early days of the project, and they
>> seem quite clean.
>> The GMS MUX flow control is at the frame level. I would guess that several frames would still need to be fit into the buffer for it to be effective. It is
>> implemented on a per-channel basis, and a short description (from the blox manual) is:
>> http://read.pudn.com/downloads406/ebook/1729787/MuxImplementation_ApplicationNote_(WLS-CS-11002).pdf
>> 6.3 FlowControlonvirtualchannels
>> The Flow control of the virtual channel is implemented in terms of MSC packets with the FC bit. If the application processor sets the FC bit to 1 for a
>> particular DLC, the TE does not send data to the application processor for that DLC until FC returns to 0 for the same DLC. The TE has limited resources
>> for buffering data, so if the DLC is involved in large data transfers (for example downloading data through a GPRS connection) a buffer overflow may
>> occur if the time between FC=1 and FC=0 is too long; in this case data may be lost and there is no error indication.
>> The application processor should avoid (if possible) the use of this feature or keep the time interval with the FC=1 as small as possible.
>> I never really did any optimisation of the SIMCOM (or MUX) driver at all. The MUX in particular was written by looking at other implementations, as the
>> protocol specification has gone the way of most standards body specifications and is mostly undecipherable. I think there is some opportunity for improvement
>> (but given our low bandwidth requirements at the time we never had the incentive). Flow control is not implemented at all.
>> Regards, Mark
>>> On 23 Oct 2019, at 3:01 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>> Mark,
>>> also not trying to sound too negative… but please read: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/274
>>> The flashing process is done with hardware flow control. With Wifi enabled, we cannot even handle 115 kbit without fifo overflows.
>>> We can try the MUX flow control you mentioned, but will it be able to throttle transmission within frames longer than the HW FIFO?
>>> Btw, I've got an improvement on fifo overflow recovery in testing, if you want to work on this, I can push my changes this evening.
>>> Am 23.10.19 um 08:50 schrieb Mark Webb-Johnson:
>>>> But perhaps I am unintentionally sounding too negative...
>>>> The biggest hurdle to this working technically is undoubtedly the LWIP support for SNAT and routing. If the library you caption (jonask1337/esp-lwip)
>>>> solves that, it makes this technically feasible.
>>>> My comments on baud rate on the UART link between ESP32 and SIMCOM are more about the practicality of it. That could be tested with a few simple
>>>> modifications to our SIMCOM driver, to see how fast it could actually be driven. I know we get up to about 1Mbps for firmware flashing without an issue,
>>>> and the ESP32 hardware UART is up to 5Mbps.
>>>> It would be a fantastic feature to have, and incredibly useful.
>>>> Regards, Mark.
>>>>> On 23 Oct 2019, at 2:33 PM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>>>>> The connection between the SIMCOM and the ESP32 is 115,200 baud. That could be increased (in software), and there is software flow control on the GSM MUX
>>>>> we use (although I have no idea if SIMCOM implements it); but without hardware flow control lines I don’t think it could/would approach 3G speeds.
>>>>> The alternative is to swap it around. Put the modem and the SIM in some other device designed for that purpose, and have OVMS connect to that as a WiFi
>>>>> client.
>>>>> Regards, Mark.
>>>>>> On 23 Oct 2019, at 2:23 PM, Peter Lord <plord12 at gmail.com <mailto:plord12 at gmail.com>> wrote:
>>>>>> Hi All,
>>>>>> I've been lurking here for a while still debating wether to ditch my autopi in favour of OVMS.
>>>>>> One thing thats held me back is to find a way to use the wifi hotspot as a NAT router - this is
>>>>>> useful to allow my sat nav to get traffic and charging point updates. As far as I can see on
>>>>>> the web page this isn't currently supported.
>>>>>> However I did see a couple of projects that adds NAT support to lwip :
>>>>>> https://github.com/martin-ger/lwip_nat_arduino
>>>>>> https://github.com/jonask1337/esp-lwip
>>>>>> Does anyone know if adding NAT has a fighting chance ?
>>>>>> Cheers,
>>>>>> Pete
>>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191023/87343dc0/attachment-0001.html>
