[Ovmsdev] Added Pushover and SSL client support
Marko Juhanne
marko.juhanne at gmail.com
Tue Oct 22 12:00:47 HKT 2019
Michael,
thanks for the clarification.
The manual send command in fact doesn't need activation (the config flag is
there for only to enable forwarding the filtered notifications and events).
Br,
Marko
On Mon, Oct 21, 2019 at 11:34 PM Michael Balzer <dexter at expeedo.de> wrote:
> Marko,
> it's about saving RAM and CPU load, saving boot time and keeping the
> processing queues as small as possible for the user configuration. There
> should be no running tasks or registered listeners if a service isn't
> activated, and buffers shouldn't be preallocated etc.. Basically just the
> component resting in ROM, waiting for activation by the user.
> But you're right, if the service has no permanent connection and doesn't
> have a task or complex state, the explicit start/stop scheme isn't strictly
> necessary and can be done implicitly by listening to the config.
> Just take care to only register your notify reader once and reuse the
> reader id on later reactivation. Reason: the notify registry has no reusing
> mechanism but always allocates the next bit for a new reader (and bits are
> limited).
> As a side note: if it's simply a https client wrapper, maybe the manual
> send command shouldn't need an activated service at all?
> Am 21.10.19 um 21:51 schrieb Marko Juhanne:
> Hi Michael,
> I've now made changes it so that sending notifications is retried when
> connectivity is restored, and also made the filtering smarter so that no
> unnecessary messages are retained.
> Before continuing with this service start/stop feature, just wanted to
> make sure what is it we are trying to accomplish. Is this to save memory
> and/or CPU cycles? I mean, there is no persistent connection to the
> Pushover service, but every notification/message is sent with a separate
> connection. And there's also the "enable pushover service" config to
> disable forwarding the notifications to Pushover service. I could make it
> even faster/efficient via deregistering the reader/event handler when the
> service is disabled.
> But I'm slightly tilted against to changing the Pushover class to mimic
> OvmsServer (e.g. starting/stopping the server by creating a separate
> instance), since then sending test messages by console or web UI we need
> facilities to check if server is running, and starting and stopping it on
> demand via web UI and console etc.. IMHO this adds unnecessary complexity,
> since Pushover class is basically just a https client wrapper with a
> notification/event handler, the latter which can be disabled easily.
> But please correct me if I've overlooked something or if you had something
> else in mind.
> Best regards,
> Marko
> On Sat, Oct 19, 2019 at 1:41 PM Michael Balzer <dexter at expeedo.de> wrote:
>> …or alternatively / additional to the pcp scheme implement "start" &
>> "stop" commands as shown by the v2/v3 servers.
>> Am 19.10.19 um 12:38 schrieb Michael Balzer:
>> Marko,
>> I guess you already saw my quick fix to the pushover module. Failing to
>> clear the "read" flag leads to messages being held indefinitely by the
>> notification system.
>> The fix is no real solution, as the current implementation will drop
>> messages being raised during a network outage. A notify reader may use the
>> "read" flag to keep the messages on temporary loss of connectivity, but it
>> needs to retry sending itself. There is no automatic re-delivery of
>> messages. So you need to add some flag telling the component to check for
>> undelivered messages, as is shown in the server v2 / v3 code.
>> Also, as you're able to tell by your nice filter mechanism if a
>> notification should be sent to the pushover service, you should check that
>> filter already in the filter callback. By doing so, messages without actual
>> readers won't be queued in the first place, so that saves processing time
>> and RAM.
>> I was also surprised by the service running without activation. The
>> standard scheme for optional components is to implement the "pcp" power
>> control scheme and add an AutoInit() integration.
>> Am 18.10.19 um 15:25 schrieb Michael Balzer:
>> The Pushover support isn't enabled now in our default builds, because…
>> a) MBEDTLS_PSK_MODES defaults to "no"
>> b) MG_ENABLE_SSL also defaults to "no"
>> c) OVMS_COMP_PUSHOVER would default to "yes" but depends on a) + b)
>> Should we set these to "yes" for the edge release now?
>> Am 29.07.19 um 21:07 schrieb Marko Juhanne:
>> Hello all,
>> I've been wanting to have a bit more configurable notification system on
>> my mobile phone compared to the OVMS mobile app (quiet hours, different
>> message priority levels, override quiet hours with emergency priority,
>> custom sounds, persistent notifications demanding acknowledgment etc). I
>> already use Pushover as notification platform for my home automation system
>> and it has worked nicely for these two past years so I decided to port
>> Pushover client to OVMS as well.
>> For those who don't know, Pushover is a notification platform that has
>> apps for iOS and Android. They also have a desktop (actually web)
>> application as well. You create an account and then register your
>> application. There's a 5 USD per platform one-time fee, which I find quite
>> reasonable. Message limit is 7500 messages / month / application. So if
>> you have multiple cars, you could register them as individual
>> applications. I'm not affiliated with the company, just a happy customer.
>> There are now commits for Pushover support on my fork (
>> https://github.com/mjuhanne/Open-Vehicle-Monitoring-System-3). It's up
>> to date with the main branch, and has the SWCAN commits as well. I would
>> appreciate if others could test it before making a pull request, since
>> there are now quite many changes. I didn't want to add another http
>> client, so I used Mongoose. But then after enabling SSL support using
>> mbedssl I found out that there's this client space "struct mg_connect_opts"
>> that will be too small (and causes crash) if MG_ENABLE_SSL is not enabled
>> also in every component that uses Mongoose.
>> To configure Pushover, there's a new Config/Notifications page on OVMS.
>> You can filter which notifications and events will be relayed and select
>> their priority levels accordingly. I thought about using web config
>> pluging, but maybe we could integrate this page to configure notifications
>> for OVMS mobile apps as well?
>> Best regards,
>> Marko Juhanne
>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191022/7d5f41ae/attachment.html>
