[Ovmsdev] Added Pushover and SSL client support
Mon Oct 21 14:11:36 HKT 2019
That seems ok. Can you handle it, Michael? Update the sdkconfig defaults, and I’ll update my live server when ready.
> On 18 Oct 2019, at 9:25 PM, Michael Balzer <dexter at expeedo.de> wrote:
> The Pushover support isn't enabled now in our default builds, because…
> a) MBEDTLS_PSK_MODES defaults to "no"
> b) MG_ENABLE_SSL also defaults to "no"
> c) OVMS_COMP_PUSHOVER would default to "yes" but depends on a) + b)
> Should we set these to "yes" for the edge release now?
> Am 29.07.19 um 21:07 schrieb Marko Juhanne:
>> Hello all,
>> I've been wanting to have a bit more configurable notification system on my mobile phone compared to the OVMS mobile app (quiet hours, different message priority levels, override quiet hours with emergency priority, custom sounds, persistent notifications demanding acknowledgment etc). I already use Pushover as notification platform for my home automation system and it has worked nicely for these two past years so I decided to port Pushover client to OVMS as well.
>> For those who don't know, Pushover is a notification platform that has apps for iOS and Android. They also have a desktop (actually web) application as well. You create an account and then register your application. There's a 5 USD per platform one-time fee, which I find quite reasonable. Message limit is 7500 messages / month / application. So if you have multiple cars, you could register them as individual applications. I'm not affiliated with the company, just a happy customer.
>> There are now commits for Pushover support on my fork (https://github.com/mjuhanne/Open-Vehicle-Monitoring-System-3 <https://github.com/mjuhanne/Open-Vehicle-Monitoring-System-3>). It's up to date with the main branch, and has the SWCAN commits as well. I would appreciate if others could test it before making a pull request, since there are now quite many changes. I didn't want to add another http client, so I used Mongoose. But then after enabling SSL support using mbedssl I found out that there's this client space "struct mg_connect_opts" that will be too small (and causes crash) if MG_ENABLE_SSL is not enabled also in every component that uses Mongoose.
>> To configure Pushover, there's a new Config/Notifications page on OVMS. You can filter which notifications and events will be relayed and select their priority levels accordingly. I thought about using web config pluging, but maybe we could integrate this page to configure notifications for OVMS mobile apps as well?
>> Best regards,
>> Marko Juhanne
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191021/44705ba7/attachment.html>
