[Ovmsdev] Added Pushover and SSL client support
Sat Oct 19 18:40:55 HKT 2019
…or alternatively / additional to the pcp scheme implement "start" & "stop" commands as shown by the v2/v3 servers.
Am 19.10.19 um 12:38 schrieb Michael Balzer:
> Marko,
> I guess you already saw my quick fix to the pushover module. Failing to clear the "read" flag leads to messages being held indefinitely by the notification
> system.
> The fix is no real solution, as the current implementation will drop messages being raised during a network outage. A notify reader may use the "read" flag to
> keep the messages on temporary loss of connectivity, but it needs to retry sending itself. There is no automatic re-delivery of messages. So you need to add
> some flag telling the component to check for undelivered messages, as is shown in the server v2 / v3 code.
> Also, as you're able to tell by your nice filter mechanism if a notification should be sent to the pushover service, you should check that filter already in
> the filter callback. By doing so, messages without actual readers won't be queued in the first place, so that saves processing time and RAM.
> I was also surprised by the service running without activation. The standard scheme for optional components is to implement the "pcp" power control scheme and
> add an AutoInit() integration.
> Am 18.10.19 um 15:25 schrieb Michael Balzer:
>> The Pushover support isn't enabled now in our default builds, because…
>> a) MBEDTLS_PSK_MODES defaults to "no"
>> b) MG_ENABLE_SSL also defaults to "no"
>> c) OVMS_COMP_PUSHOVER would default to "yes" but depends on a) + b)
>> Should we set these to "yes" for the edge release now?
>> Am 29.07.19 um 21:07 schrieb Marko Juhanne:
>>> Hello all,
>>> I've been wanting to have a bit more configurable notification system on my mobile phone compared to the OVMS mobile app (quiet hours, different message
>>> priority levels, override quiet hours with emergency priority, custom sounds, persistent notifications demanding acknowledgment etc). I already use
>>> Pushover as notification platform for my home automation system and it has worked nicely for these two past years so I decided to port Pushover client to
>>> OVMS as well.
>>> For those who don't know, Pushover is a notification platform that has apps for iOS and Android. They also have a desktop (actually web) application as
>>> well. You create an account and then register your application. There's a 5 USD per platform one-time fee, which I find quite reasonable. Message limit is
>>> 7500 messages / month / application. So if you have multiple cars, you could register them as individual applications. I'm not affiliated with the
>>> company, just a happy customer.
>>> There are now commits for Pushover support on my fork (https://github.com/mjuhanne/Open-Vehicle-Monitoring-System-3). It's up to date with the main branch,
>>> and has the SWCAN commits as well. I would appreciate if others could test it before making a pull request, since there are now quite many changes. I
>>> didn't want to add another http client, so I used Mongoose. But then after enabling SSL support using mbedssl I found out that there's this client space
>>> "struct mg_connect_opts" that will be too small (and causes crash) if MG_ENABLE_SSL is not enabled also in every component that uses Mongoose.
>>> To configure Pushover, there's a new Config/Notifications page on OVMS. You can filter which notifications and events will be relayed and select their
>>> priority levels accordingly. I thought about using web config pluging, but maybe we could integrate this page to configure notifications for OVMS mobile
>>> apps as well?
>>> Best regards,
>>> Marko Juhanne
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191019/df56d34e/attachment-0001.html>
