[Ovmsdev] WifiConsole V1.0
Mon Oct 14 01:54:12 HKT 2019
Sending notifications is now also supported directly:
https://docs.openvehicles.com/en/latest/userguide/scripting.html#ovmsnotify
Am 13.10.19 um 16:09 schrieb Jaunius Kapkan:
> Great,
> Will try that out!
> Jaunius
>> Sent: Sunday, October 13, 2019 at 11:20 AM
>> From: "Michael Balzer" <dexter at expeedo.de>
>> To: ovmsdev at lists.openvehicles.com
>> Subject: Re: [Ovmsdev] WifiConsole V1.0
>> Jaunius,
>> I've added scheduled (delayed) events & the native OvmsEvents API:
>> https://docs.openvehicles.com/en/latest/userguide/scripting.html#internal-objects-and-functions-methods
>> So you can now also implement millisecond resolution timeouts and intervals in scripts.
>> Am 11.10.19 um 10:36 schrieb Jaunius Kapkan:
>>> Thanks Michael,
>>> 1 second will do just fine as this is for climate control timer plugin I'm doing. Will try to use that event listener. Of course some standartized way would
>>> be better.
>>> Jaunius
>>> *Sent:* Friday, October 11, 2019 at 8:48 AM
>>> *From:* "Michael Balzer" <dexter at expeedo.de>
>>> *To:* ovmsdev at lists.openvehicles.com
>>> *Subject:* Re: [Ovmsdev] WifiConsole V1.0
>>> Jaunius,
>>> setTimeout() is not a standard Javascript function, it's a method of the browser window object.
>>> https://developer.mozilla.org/de/docs/Web/API/WindowTimers/setTimeout
>>> As a workaround, subscribe to the "ticker.1" event as shown in the foglight example:
>>> http://docs.openvehicles.com/en/latest/components/ovms_script/docs/foglight.html#listen-to-events
>>> Resolution is limited to 1 second though. I thought about scheduled events some time ago, i.e. being able to tell the event system to trigger an event after a
>>> specific delay. That would also offer a clean & simple solution for this. Another option would be a script API for the timer service.
>>> I'll have a look at scheduled events.
>>> Am 11.10.19 um 08:29 schrieb Jaunius Kapkan:
>>>     Thanks Mark,
>>>     One other thing I stumbled upon is that standard setTimeout() does not seem to work. Is there any workaround for this? Sample Code:
>>>     |function intervalFunc() { print('Next try in 1.5s') } setInterval(intervalFunc, 1500)|
>>>     Basically I need the script to check certain conditions each n seconds.
>>>     Regards,
>>>     Jaunius
>>>     *Sent:* Thursday, October 10, 2019 at 3:35 AM
>>>     *From:* "Mark Webb-Johnson" <mark at webb-johnson.net>
>>>     *To:* "OVMS Developers" <ovmsdev at lists.openvehicles.com>
>>>     I think in v2 that could have been the case (as we didn’t have any standardised functions for things like climate control). But in the v3 architecture we
>>>     now have these and the vehicle modules should support the standard functions to the best of their abilities.
>>>     If we still need mappings like Homelink 1 -> Climate On, then that should be done either by scripts or by some centralised mapping framework.
>>>     Regards, Mark.
>>>     > On 9 Oct 2019, at 2:19 PM, Jaunius Kapkan <jaunius at gmx.com> wrote:
>>>     > I am making a couple of plugins (initially for leaf) and the JS functions are great for that. However I assume the functions are not unifed accross
>>>     different vehicles. For example for leaf to turn on pre-heat you need to issue Homelink 1 instead of ClimateControl. What would be the best way to change
>>>     this? Or is this something that need to be changed on the lower level?
>>>     > Greetings,
>>>     > Jaunius
>>>     >> Sent: Tuesday, October 08, 2019 at 9:05 AM
>>>     >> Mark,
>>>     >> yes, the OLEDs are perfect for these things, bright enough for daylight use with very little energy usage.
>>>     >> Thanks for the link to that combined ESP32 module, that's a real beauty, even includes a LiPo supply / charger. I need to check that one out.
>>>     >> Regarding our Javascript support, I already had stunned some users with the foglight plugin, they thought stuff like this would need builtin
>>>     >> support. That brought me back to my point about how little users know about our capabilities, so I added an explanation to our docs:
>>>     >> But we really need something like an OVMS cheat sheet as an overview of what is possible.
>>>     >> Regards,
>>>     >> Michael
>>>     >> Am 08.10.19 um 05:40 schrieb Mark Webb-Johnson:
>>>     >>> Michael,
>>>     >>> I really like those little OLED SSD1306 based displays. I use them on my esphome+hassio projects like this little water tank level (using an
>>>     >>> ESP32, a BME280 pressure/humidity/temperature sensor, waterproof ultrasonic distance sensor, and SSID1306 OLED yellow/blue display):
>>>     >>> Adding a display to a project makes it so much more useful and easy to diagnose problems.
>>>     >>> AliExpress has them very cheap:
>>>     >>> * https://www.aliexpress.com/item/32844104782.html
>>>     >>> US$2 for the 0.96” yellow/blue 128x32
>>>     >>> US$3 for the 1.3” white 128x64
>>>     >>> There is also a 4MB ESP32 with a 0.96” OLED display on-board:
>>>     >>> * https://www.aliexpress.com/item/32822105291.html
>>>     >>> US$9 plus shipping
>>>     >>> Glad that you are finding a use for our JavaScript support. I really think that has so many possibilities.
>>>     >>> Regards, Mark
>>>     >>>> On 6 Oct 2019, at 10:43 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>     >>>> FYI: I've just implemented an OVMS v3 style replacement for the SimpleConsole:
>>>     >>>> https://github.com/dexterbg/WifiConsole
>>>     >>>> V3 makes it pretty easy now to add stuff like this. It's using a script plugin to provide custom functions via the web API.
>>>     >>>> Regards,
>>>     >>>> Michael
>>>     >> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>     >> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
>>>     >> _______________________________________________
>>>     >> OvmsDev mailing list
>>>     >> OvmsDev at lists.openvehicles.com
>>>     >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>> _______________________________________________ OvmsDev mailing list OvmsDev at lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
