[Ovmsdev] WifiConsole V1.0
Fri Oct 11 14:48:54 HKT 2019
Jaunius,
setTimeout() is not a standard Javascript function, it's a method of the browser window object.
https://developer.mozilla.org/de/docs/Web/API/WindowTimers/setTimeout
As a workaround, subscribe to the "ticker.1" event as shown in the foglight example:
http://docs.openvehicles.com/en/latest/components/ovms_script/docs/foglight.html#listen-to-events
Resolution is limited to 1 second though. I thought about scheduled events some time ago, i.e. being able to tell the event system to trigger an event after a
specific delay. That would also offer a clean & simple solution for this. Another option would be a script API for the timer service.
I'll have a look at scheduled events.
Am 11.10.19 um 08:29 schrieb Jaunius Kapkan:
> Thanks Mark,
> One other thing I stumbled upon is that standard setTimeout() does not seem to work. Is there any workaround for this? Sample Code:
> |function intervalFunc() { print('Next try in 1.5s') } setInterval(intervalFunc, 1500)|
> Basically I need the script to check certain conditions each n seconds.
> Jaunius
> *Sent:* Thursday, October 10, 2019 at 3:35 AM
> *From:* "Mark Webb-Johnson" <mark at webb-johnson.net>
> *To:* "OVMS Developers" <ovmsdev at lists.openvehicles.com>
> *Subject:* Re: [Ovmsdev] WifiConsole V1.0
> I think in v2 that could have been the case (as we didn’t have any standardised functions for things like climate control). But in the v3 architecture we now
> have these and the vehicle modules should support the standard functions to the best of their abilities.
> If we still need mappings like Homelink 1 -> Climate On, then that should be done either by scripts or by some centralised mapping framework.
> > On 9 Oct 2019, at 2:19 PM, Jaunius Kapkan <jaunius at gmx.com> wrote:
> > I am making a couple of plugins (initially for leaf) and the JS functions are great for that. However I assume the functions are not unifed accross
> different vehicles. For example for leaf to turn on pre-heat you need to issue Homelink 1 instead of ClimateControl. What would be the best way to change
> this? Or is this something that need to be changed on the lower level?
> > Greetings,
> > Jaunius
> >> Sent: Tuesday, October 08, 2019 at 9:05 AM
> >> From: "Michael Balzer" <dexter at expeedo.de>
> >> To: ovmsdev at lists.openvehicles.com
> >> Subject: Re: [Ovmsdev] WifiConsole V1.0
> >> Mark,
> >> yes, the OLEDs are perfect for these things, bright enough for daylight use with very little energy usage.
> >> Thanks for the link to that combined ESP32 module, that's a real beauty, even includes a LiPo supply / charger. I need to check that one out.
> >> Regarding our Javascript support, I already had stunned some users with the foglight plugin, they thought stuff like this would need builtin
> >> support. That brought me back to my point about how little users know about our capabilities, so I added an explanation to our docs:
> >> But we really need something like an OVMS cheat sheet as an overview of what is possible.
> >> Regards,
> >> Michael
> >> Am 08.10.19 um 05:40 schrieb Mark Webb-Johnson:
> >>> Michael,
> >>> I really like those little OLED SSD1306 based displays. I use them on my esphome+hassio projects like this little water tank level (using an
> >>> ESP32, a BME280 pressure/humidity/temperature sensor, waterproof ultrasonic distance sensor, and SSID1306 OLED yellow/blue display):
> >>> Adding a display to a project makes it so much more useful and easy to diagnose problems.
> >>> AliExpress has them very cheap:
> >>> * https://www.aliexpress.com/item/32844104782.html
> >>> US$2 for the 0.96” yellow/blue 128x32
> >>> US$3 for the 1.3” white 128x64
> >>> There is also a 4MB ESP32 with a 0.96” OLED display on-board:
> >>> * https://www.aliexpress.com/item/32822105291.html
> >>> US$9 plus shipping
> >>> Glad that you are finding a use for our JavaScript support. I really think that has so many possibilities.
> >>> Regards, Mark
> >>>> On 6 Oct 2019, at 10:43 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
> >>>> FYI: I've just implemented an OVMS v3 style replacement for the SimpleConsole:
> >>>> https://github.com/dexterbg/WifiConsole
> >>>> V3 makes it pretty easy now to add stuff like this. It's using a script plugin to provide custom functions via the web API.
> >>>> Regards,
> >>>> Michael
> >> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
> >> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
> >> _______________________________________________
> >> OvmsDev mailing list
> >> OvmsDev at lists.openvehicles.com
> >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191011/6f130742/attachment-0001.html>
