[Ovmsdev] WifiConsole V1.0
Jaunius Kapkan jaunius at gmx.com
Wed Oct 9 14:19:46 HKT 2019
I am making a couple of plugins (initially for leaf) and the JS functions are great for that. However I assume the functions are not unifed accross different vehicles. For example for leaf to turn on pre-heat you need to issue Homelink 1 instead of ClimateControl. What would be the best way to change this? Or is this something that need to be changed on the lower level?
Greetings,
Jaunius
> Sent: Tuesday, October 08, 2019 at 9:05 AM
> From: "Michael Balzer" <dexter at expeedo.de>
> To: ovmsdev at lists.openvehicles.com
> Subject: Re: [Ovmsdev] WifiConsole V1.0
> Mark,
> yes, the OLEDs are perfect for these things, bright enough for daylight use with very little energy usage.
> Thanks for the link to that combined ESP32 module, that's a real beauty, even includes a LiPo supply / charger. I need to check that one out.
> Regarding our Javascript support, I already had stunned some users with the foglight plugin, they thought stuff like this would need builtin
> support. That brought me back to my point about how little users know about our capabilities, so I added an explanation to our docs:
> http://docs.openvehicles.com/en/latest/components/ovms_script/docs/foglight.html
> But we really need something like an OVMS cheat sheet as an overview of what is possible.
> Am 08.10.19 um 05:40 schrieb Mark Webb-Johnson:
> > Michael,
> > I really like those little OLED SSD1306 based displays. I use them on my esphome+hassio projects like this little water tank level (using an
> > ESP32, a BME280 pressure/humidity/temperature sensor, waterproof ultrasonic distance sensor, and SSID1306 OLED yellow/blue display):
> > Adding a display to a project makes it so much more useful and easy to diagnose problems.
> > AliExpress has them very cheap:
> >   * https://www.aliexpress.com/item/32844104782.html
> >     US$2 for the 0.96” yellow/blue 128x32
> >     US$3 for the 1.3” white 128x64
> > There is also a 4MB ESP32 with a 0.96” OLED display on-board:
> >   * https://www.aliexpress.com/item/32822105291.html
> >     US$9 plus shipping
> > Glad that you are finding a use for our JavaScript support. I really think that has so many possibilities.
> > Regards, Mark
> >> On 6 Oct 2019, at 10:43 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
> >> FYI: I've just implemented an OVMS v3 style replacement for the SimpleConsole:
> >> https://github.com/dexterbg/WifiConsole
> >> V3 makes it pretty easy now to add stuff like this. It's using a script plugin to provide custom functions via the web API.
> >> Regards,
> >> Michael
