[Ovmsdev] Scripting - missing integrations
Tue Oct 8 16:25:50 HKT 2019
Also missing:
* OvmsEvent (raise)
* OvmsNotify (raise)
…these would be especially valuable for communication between module and web plugins as well as MQTT listeners.
We also need an HTTP/HTTPS client accessable from scripts. Our OvmsHttp implementation needs to be replaced by the IDF HTTPS client.
Simple file I/O for scripts would also be valuable (e.g. scripts writing custom data logs to SD).
Script access to protected config values could be granted by a general API key mechanism, as planned for the web API (/api/execute). I.e. the
script needs to use a valid API token to access protected configs. An API token could include a set of specific grants & denies, so we can
extend that as needed to also cover other potentially critical stuff like network & file access. Similar to App permissions on Android / iOS.
Am 08.10.19 um 09:45 schrieb Mark Webb-Johnson:
> Michael’s work has brought up an issue that we seem to be missing some javascript integrations.
> We have:
> * OvmsCommand
> * OvmsLocation
> * OvmsMetrics
> * OvmsVehicle
> * PubSub (to ovms events)
> Obvious ones missing are:
> * OvmsConfig
> * OvmsWebServer
> I can do OvmsConfig, but one question: Do we allow scripts access to protected config values? I think not (as that would void the entire
> protection system with a ’script eval JSON.print(…)', but is a limitation). Comments?
> It would be interesting to see scripts extend the OvmsWebServer, so urls could be mapped to scripts - but not sure of the practical use of
> that vs plugins.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191008/cd28eda3/attachment.html>
