[Ovmsdev] Cannot reset simcom stuck in PoweringOn state without removing module power
Mon Nov 18 05:39:14 HKT 2019
Forgot: you can check if the pullup is working by monitoring the voltage level on the SIMCOM PWRKEY pin, that's pin 3. When MDM_EN is high the transistor should
draw that to GND.
Pin 3 is the third from the top on the left side (SIMCOM label wise).
The driver puts MDM_EN to high for a whole second, so that should be clearly visible. Without the pullup, you should only see a very short pulse, if at all.
Am 17.11.19 um 22:29 schrieb Michael Balzer:
> Craig,
> Am 17.11.19 um 19:31 schrieb Craig Leres:
>> On 2019-11-17 04:11, Michael Balzer wrote:
>>> I also saw this & can also reproduce this on my workbench.
>> What is the method to induce the problem?
> No method. If the theory is right it depends on a combination of random circumstances if the MDM_EN signal is long enough for the modem to recognize.
> I've got a module from the very first batch (3.0) and a 3.1 development module on my bench. The 3.0 module can power on/off the modem from port 0, the 3.1
> cannot. It may also be related to some other condition, as I think the 3.1 module was able to control modem power at least once.
>>> Maybe a fix for existing boards could be adding a pullup resistor at the transistor base?
>> I could try this if you suggest a value (and perhaps mark up a schematic?)
> I think something in the range 130-150K should work. That should put the base to ~0.5-0.6V for low and to ~1.0-1.2V for high. That's either not fully switched
> off on low or not fully saturated on high, but should be sufficient for the modem.
> Schematic:
> PCB (down side):
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191117/7dbb7a00/attachment.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191117/7dbb7a00/attachment-0004.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191117/7dbb7a00/attachment-0005.png>
