[Ovmsdev] Time variable
Thu Nov 7 14:40:43 HKT 2019
Tamás, I’ve committed this fix to our simcom driver (relatively easy as we only support SIM5360 currently). It is on api.openvehicles.com <http://api.openvehicles.com/> OTA as:
3.2.005-102-g1a4364f
Please try and let us know if it resolves this for you.
P.S. Thanks for noticing and raising this so quickly.
> On 7 Nov 2019, at 2:27 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Like this (experiment):
> $ ./t.pl
> UTC original = Wed Mar 22 20:28:27 2000
> UTC adjusted = Wed Nov  6 20:28:27 2019
> $ cat t.pl
> #!/usr/bin/perl
> use POSIX qw(strftime);
> use Time::Local;
> my @original = (27,28,20,22,3-1,2000-1900,0);
> print "UTC original = ", strftime("%a %b %e %H:%M:%S %Y", at original),"\n";
> my $jdt = timegm(@original);
> my $ajdt = $jdt + (1024 * 7 * 86400);
> my ($sec,$min,$hour,$mday,$mon,$year,$wday,$yday,$isdst) = gmtime($ajdt);
> print "UTC adjusted = ", strftime("%a %b %e %H:%M:%S %Y",($sec,$min,$hour,$mday,$mon,$year,$wday,$yday,$isdst)),"\n";
> @Tamás: Does the above adjustment show the correct date/time (Wed Nov  6 20:28:27 2019 UTC)?
>> On 7 Nov 2019, at 2:13 PM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>> The issue is that we don’t have week numbers from the GPS (and presumably week to date is non-trivial).
>> We get the date/time from the NMEA RMC message, then pass it into this to convert to a julian date/time:
>>  * utc_to_timestamp:
>>  *  convert GPS date & time (UTC) to timestamp
>>  *   date: "ddmmyy"
>>  *   time: "hhmmss"
>> static unsigned long utc_to_timestamp(const char* date, const char* time)
>>   int day, month, year, hour, minute, second;
>>   day = (date[0]-'0')*10 + (date[1]-'0');
>>   month = (date[2]-'0')*10 + (date[3]-'0');
>>   year = (date[4]-'0')*10 + (date[5]-'0');
>>   hour = (time[0]-'0')*10 + (time[1]-'0');
>>   minute = (time[2]-'0')*10 + (time[3]-'0');
>>   second = (time[4]-'0')*10 + (time[5]-'0');
>>   return
>>     (JdFromYMD(2000+year, month, day) - JDEpoch) * (24L * 3600)
>>       + ((hour * 60L + minute) * 60) + second;
>> Perhaps sufficient to add 1024 * 7 * 86400 to that?
>>> On 7 Nov 2019, at 1:44 PM, Stephen Casner <casner at acm.org <mailto:casner at acm.org>> wrote:
>>> Mark,
>>> You don't need the condition "date <2019-11-03", just always add 1024
>>> weeks to the current time value coming from the modem.
>>>                                                        -- Steve
>>> On Thu, 7 Nov 2019, Mark Webb-Johnson wrote:
>>>> Damn:
>>>> https://www.cika.com/soporte/Information/GSMmodules/GPS-week-rollover_Simcom.pdf <https://www.cika.com/soporte/Information/GSMmodules/GPS-week-rollover_Simcom.pdf> <https://www.cika.com/soporte/Information/GSMmodules/GPS-week-rollover_Simcom.pdf <https://www.cika.com/soporte/Information/GSMmodules/GPS-week-rollover_Simcom.pdf>>
>>>> I think we can do a fix in the SIMCOM module that if the date <2019-11-03 then offset it somehow? Any ideas?
>>>> Regards, Mark.
>>>>> On 7 Nov 2019, at 1:09 PM, Stephen Casner <casner at acm.org <mailto:casner at acm.org>> wrote:
>>>>> This page mentions the problem:
>>>>> https://techship.com/news/gps-week-roll-over-issue-during-epoch-restart/ <https://techship.com/news/gps-week-roll-over-issue-during-epoch-restart/>
>>>>> Quoting there:
>>>>>   For the Qualcomm MDM9x15 series (4G/LTE Cat 3) and MDM6200
>>>>>   (3G/HSPA+) series chipsets there is a offset used, so the GPS week
>>>>>   roll over will occur 1054+1023 weeks since launch of the GPS, and
>>>>>   more precisely in beginning of November 2019 (UTC 23:59:42
>>>>>   November 2, 2019)
>>>>>   [snip]
>>>>>   3G/HSPA+ modules based on Qualcomm MDM6200 series chipsets:
>>>>>   Huawei EM820W / MU609 series
>>>>>   Telit DE910 series
>>>>>   Simcom SIM5320 series
>>>>> This sounds like the hardware/firmware won't be fixed.  Perhaps the
>>>>> solution for OVMS is just to put an offset as a workaroud.  That will
>>>>> work for the next 1024 weeks.
>>>>>                                                       -- Steve
>>>>> On Wed, 6 Nov 2019, Stephen Casner wrote:
>>>>>> Sorry, I did not read carefully.  The item you mentioned is just an
>>>>>> antenna.  The GPS implementation is in the modem module, correct?
>>>>>> That's where the correction is needed.
>>>>>>                                                       -- Steve
>>>>>> On Thu, 7 Nov 2019, Tamás Kovács wrote:
>>>>>>> I use a universal gps connected to ovms, not the car own gps. (
>>>>>>> https://www.fasttech.com/products/1020200 <https://www.fasttech.com/products/1020200>)
>>>>>>> Stephen Casner <casner at acm.org <mailto:casner at acm.org>> ezt írta (időpont: 2019. nov. 7., Cs, 0:42):
>>>>>>>> Tamás,
>>>>>>>> This looks like the GPS sensor did not handle the rollover of the
>>>>>>>> 10-bit week-number field in April, 2019.  So the timestamps are off by
>>>>>>>> 1024 * 7 * 24 * 60 * 60 seconds.  Here is the US government alert about
>>>>>>>> this problem:
>>>>>>>> https://www.us-cert.gov/sites/default/files/documents/Memorandum_on_GPS_2019.pdf <https://www.us-cert.gov/sites/default/files/documents/Memorandum_on_GPS_2019.pdf>
>>>>>>>> This problem was recently discovered for the Garmin GPS 18x LVC
>>>>>>>> sensors in the Tesla Roadster 2.5 (but not in the earlier 1.5 version
>>>>>>>> like I have, which has the older GPS 18 LVC sensor):
>>>>>>>> https://teslamotorsclub.com/tmc/threads/caution-annual-service-car-power-down-gps-issue.163328/
>>>>>>>> There is a firmware update to fix this for the GPS 18x LVC.  Perhaps
>>>>>>>> there is one for the GPS sensor in the Mitsubishi as well.
>>>>>>>>                                                       -- Steve
>>>>>>>> On Wed, 6 Nov 2019, Tamás Kovács wrote:
>>>>>>>>> I have a problem with utc time, the time is correct but the date is not
>>>>>>>>> valid. I use 3.2.005-99-g88cfeef9 version with modification of Mitsubishi
>>>>>>>>> i-MiEV.
>>>>>>>>> OVMS# me li utc
>>>>>>>>> m.time.utc                               953756768Sec
>>>>>>>>> I (900675) housekeeping: 2000-03-22 21:27:06 CET (RAM: 8b=82812-86452
>>>>>>>> 32b=27308)
>>>>>>>>> I (981115) webserver: HTTP POST /api/execute
>>>>>>>>> I (981115) webcommand: HttpCommandStream[0x3fa32958]: 1984428 bytes
>>>>>>>>> free, executing: time
>>>>>>>>> OVMS# time
>>>>>>>>> Time Zone:  CET-1CEST,M3.5.0,M10.5.0/3
>>>>>>>>> UTC Time:   2000-03-22 20:28:27 UTC
>>>>>>>>> Local Time: 2000-03-22 21:28:27 CET
>>>>>>>>> Provider:   gsm-nmea
>>>>>>>>> PROVIDER             STRATUM  UPDATE TIME
>>>>>>>>> *gsm-nmea                  2       0 Wed Mar 22 20:28:27 2000
>>>>>>>>> Üdvözlettel:
>>>>>>>>> Kovács Tamás_______________________________________________
>>>>>>>> OvmsDev mailing list
>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>> Üdvözlettel:
>>>>>>> Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191107/c2c58ca5/attachment.htm>
