[Ovmsdev] 3.2.006 Release to Early Access Program
Sat Nov 30 16:37:59 HKT 2019
https://dexters-web.de/firmware-release-3.2.006-text_93.htm
Am 30.11.19 um 04:48 schrieb Mark Webb-Johnson:
> https://www.openvehicles.com/node/2346
> Today, we are pleased to release v3.2.006 to Early Access Program. A summary of the major changes is here:
> 2019-11-30 MWJ 3.2.006 OTA release
> - Web UI: Calibration and configuration aid for 12v monitor
> - Log monitoring via web shell
> - EGPIO/MAX7317: Port input monitoring, metrics, events, documentation
> - Powermgmt: New automatic power management module
> - Scripting: OvmsMetrics.AsJSON(), OvmsEvents, and OvmsNotify added
> - Logging: file logging moved to dedicated task (improved performance)
> - SWCAN: Support for add-on SWCAN module
> (see https://github.com/mjuhanne/OVMS-SWCAN)
> - Pushover: New Pushover notification framework support
> - SIMCOM: Allow user to set custom SIM PIN code
> - Metrics: 'metric list -s' shows metric age and staleness
> - Others: Factory reset from web/remote shell by
> "module factory reset -noconfirm"
> - Renault Zoe: Basic Metrics and charging status added, trip notify,
> web config for battery capacity
> - Volt/Ampera: Major update (including web config, SWCAN support, etc)
> - Twizy: Send custom OBD2 requests, output response as hex dump
> - Immediate tuning metrics updates (was delegated to ticker before)
> For full detail on all changes, check the GitHub revision history. The v3 modules can be updated over the air (wifi), via SD CARD, or over USB - all without
> requiring special hardware programmers like the PICKIT used for v2. The simplest way to update the module firmware is to connect it as a client to your wifi
> network (or phone hotspot), and then use the web interface Config / Firmware / Flash-from-Web; that will show you the version you are running, as well as the
> latest version available for update. One click on 'Flash now' and the update will be downloaded and installed. Alternatively, you can download the firmware
> update to a file named ovms3.bin in the root directory of a FAT formatted SD CARD and insert the card into the module's slot - the new firmware will be
> updated automatically and the file renamed ovms3.done to signify completion. This firmware also includes the feature to check for and automatically update to
> newly available firmware, every night (so long as the vehicle is connected to WiFi). After updating to 3.1.005 or later, you can enable this for future
> firmware releases with 'config ota auto yes'.
> You can choose the release level by setting 'config ota tag edge | eap | main', as one of:
> * edge: Bleeding edge developer nightly-builds
> * eap: Early Access Program (full releases, but with little public testing)
> * main: Publicly tested full releases (the most stable)
> Thank you to all the open source developers who have contributed to this, and previous, releases, and thank you for your support of the project.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191130/b5cab0f5/attachment.html>
