[Ovmsdev] Cannot reset simcom stuck in PoweringOn state without removing module power
Sat Nov 23 17:27:29 HKT 2019
Am 22.11.19 um 10:56 schrieb Michael Balzer:
> Am 22.11.19 um 07:25 schrieb Craig Leres:
>> As I understand it, there is no control over simcom power just control
>> of an input to simcom that requests that it powers off (or on). So is
>> the problem that it's possible to wedge the simcom in such a way that it
>> ignores the control input?
> Most likely.
… IF you've verified the modem really ignores the power down signal.
You cannot do so only by watching the OVMS log, as the UART RX may also be lost somehow. You need to check the blue LED on the modem board.
If it's a UART issue, the OVMS cannot detect any modem response and will also loop in the power up states.
> On 2019-11-22 01:56, Michael Balzer wrote:
>> What firmware version do you have on the SIMCOM?
> The one that most recently wedged is... wedged again:
> OVMS# simcom cmd AT+CGMR
> ERROR: SIMCOM command channel not available!
That may be a MUX state bug, or you may have hit the time between MUX init and established channels. See simcom::txcmd().
> But in a new way, the gps is working and the modem is registered with the network:
> PPP: Not connected
> Last Error: User Interrupt
"User Interrupt" triggers me… I had this a few days ago during the night (with wifi network in use), the module needed a reboot to recover:
2019-11-19 04:05:14 CET I (40641522) simcom: PPP Connection disconnected
2019-11-19 04:05:15 CET I (40642022) simcom: Lost network connection (+PPP disconnect in NetMode)
2019-11-19 04:05:15 CET I (40642022) simcom: State: Enter NetLoss state
2019-11-19 04:05:15 CET I (40642032) gsm-ppp: Shutting down (hard)...
2019-11-19 04:05:15 CET I (40642032) gsm-ppp: PPP is shutdown
2019-11-19 04:05:15 CET D (40642062) events: Signal(system.modem.netloss)
2019-11-19 04:05:15 CET D (40642102) events: Signal(system.modem.down)
2019-11-19 04:05:15 CET I (40642102) netmanager: Set DNS#2 0.0.0.0
2019-11-19 04:05:15 CET I (40642112) netmanager: MODEM down (with WIFI client up): staying with WIFI client priority
2019-11-19 04:05:15 CET D (40642152) events: Signal(network.modem.down)
2019-11-19 04:05:15 CET D (40642192) events: Signal(network.interface.change)
2019-11-19 04:05:20 CET I (40647522) gsm-ppp: StatusCallBack: *User Interrupt*
2019-11-19 04:05:20 CET I (40647522) gsm-ppp: PPP connection has been closed
2019-11-19 04:05:20 CET D (40647532) events: Signal(system.modem.down)
2019-11-19 04:05:20 CET I (40647532) netmanager: Set DNS#2 0.0.0.0
2019-11-19 04:05:15 CET I (40651022) simcom: State timeout, transition to 5
2019-11-19 04:05:15 CET I (40651022) simcom: State: Enter NetWait state
2019-11-19 04:05:15 CET I (40651022) gsm-nmea: Startup
2019-11-19 04:05:15 CET D (40651092) events: Signal(system.modem.netwait)
2019-11-19 04:05:27 CET I (40655022) simcom: State: Enter NetStart state
2019-11-19 04:05:27 CET D (40655062) events: Signal(system.modem.netstart)
2019-11-19 04:05:56 CET I (40684022) simcom: State timeout, transition to 14
2019-11-19 04:05:57 CET I (40684022) simcom: State: Enter PowerOffOn state
2019-11-19 04:05:57 CET I (40684022) gsm-ppp: Shutting down (soft)...
2019-11-19 04:05:57 CET I (40684022) gsm-ppp: StatusCallBack: *User Interrupt*
2019-11-19 04:05:57 CET I (40684022) gsm-ppp: PPP connection has been closed
2019-11-19 04:05:57 CET I (40684032) gsm-ppp: PPP is shutdown
2019-11-19 04:05:57 CET I (40684032) gsm-nmea: Shutdown (direct)
2019-11-19 04:05:57 CET I (40684042) gsm-mux: Stop MUX
2019-11-19 04:05:57 CET I (40684052) simcom: Power Cycle
2019-11-19 04:05:58 CET D (40685102) events: Signal(system.modem.down)
2019-11-19 04:05:58 CET I (40685102) netmanager: Set DNS#2 0.0.0.0
2019-11-19 04:05:58 CET D (40685142) events: Signal(system.modem.down)
2019-11-19 04:05:58 CET I (40685142) netmanager: Set DNS#2 0.0.0.0
2019-11-19 04:05:58 CET D (40685162) events: Signal(gps.lock.lost)
2019-11-19 04:05:58 CET D (40685192) events: Signal(system.modem.lostgps)
2019-11-19 04:05:58 CET D (40685222) events: Signal(system.modem.stop)
2019-11-19 04:05:58 CET I (40685222) netmanager: Set DNS#2 0.0.0.0
2019-11-19 04:05:58 CET D (40685262) events: Signal(egpio.output.0.high)
2019-11-19 04:05:58 CET D (40685322) events: Signal(egpio.output.0.low)
2019-11-19 04:05:59 CET I (40687022) simcom: State timeout, transition to 2
2019-11-19 04:06:00 CET I (40687022) simcom: State: Enter PoweringOn state
2019-11-19 04:06:00 CET I (40687022) simcom: Power Cycle
… looping from here in power up until reboot …
I haven't found documentation on PPPERR_USER.
> Ok, both of the modules I have in cars are 35316B07SIM5360A. My third module is the one I swapped simcoms in and is LE11B02SIM7500A (physical label says 7600A).
> I registered with techship.com and have the firmware update tool. But the only rar files I see look like they're for the European SIM5360?
They only seem to have the E version. There are some other directories on simcom.ee, but no firmware for you it seems.
Maybe we need to ask SIMCOM to provide updates?
But it also doesn't look like there's some documented issue with the modem being stuck ignoring PWRKEY. I'd first look for bugs on our side.
> Tomorrow I'll try to pull my car modules and determine if the modem boards have the pullup resistor or not.
> One last thing I'm confused about is the pullup resistor on the MEM_EN line. I don't see it on v3.1 or v3.2 schematics? I tried to complare the pdfs from
> github visually and the only difference I see is in the A0Z1280CI circuit (and I remember Mark saying they added a choke to the power supply).
It's on the main board, at the MAX7317.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191123/44a8db5f/attachment.html>
