[Ovmsdev] Cannot reset simcom stuck in PoweringOn state without removing module power
Mon Nov 18 05:29:31 HKT 2019
Craig,
Am 17.11.19 um 19:31 schrieb Craig Leres:
> On 2019-11-17 04:11, Michael Balzer wrote:
>> I also saw this & can also reproduce this on my workbench.
> What is the method to induce the problem?
No method. If the theory is right it depends on a combination of random circumstances if the MDM_EN signal is long enough for the modem to recognize.
I've got a module from the very first batch (3.0) and a 3.1 development module on my bench. The 3.0 module can power on/off the modem from port 0, the 3.1
cannot. It may also be related to some other condition, as I think the 3.1 module was able to control modem power at least once.
>> Maybe a fix for existing boards could be adding a pullup resistor at the transistor base?
> I could try this if you suggest a value (and perhaps mark up a schematic?)
I think something in the range 130-150K should work. That should put the base to ~0.5-0.6V for low and to ~1.0-1.2V for high. That's either not fully switched
off on low or not fully saturated on high, but should be sufficient for the modem.
Schematic:
PCB (down side):
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191117/92153a32/attachment-0001.html>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191117/92153a32/attachment-0002.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191117/92153a32/attachment-0003.png>
