[Ovmsdev] Distinguishing between eNiro and Kona
Peter Lord
plord12 at gmail.com
Tue Nov 5 05:37:44 HKT 2019
> On 4 Nov 2019, at 19:41, Timo Penttilä <timo.penttila at codetap.se> wrote:
> Looks nice Pete.
> My only objection is that it should be the other way around.
> Km and left hand drive as default 😉.
Actually the default is ticked - picture was for my "minority" car with the defaults unticked.
> Med Vänlig Hälsning
> TIMO PENTTILÄ
> Systemtekniker/Utvecklare
> From: OvmsDev <ovmsdev-bounces at lists.openvehicles.com <mailto:ovmsdev-bounces at lists.openvehicles.com>> On Behalf Of Peter Lord
> Sent: den 4 november 2019 20:26
> To: OVMS Developers <ovmsdev at lists.openvehicles.com <mailto:ovmsdev at lists.openvehicles.com>>
> Subject: Re: [Ovmsdev] Distinguishing between eNiro and Kona
> On 4 Nov 2019, at 05:33, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
> In general, it is best to differentiate different models/features based on CAN bus traffic - although I realise that can be non-trivial at least when starting a project and only your own car’s logs to see. Perhaps others can collaborate with log captures from different variants?
> Thanks - Googling I don't believe the VIN number has enough info, as you say trying to figure out much from OBD data is challenging to say the least :-)
> I do have the features I need implemented locally and it appears to work for what I need :
> I'll ponder this some more before creating a pull request.
> You can have a config-based override / setting for this. It is easy to check IsDefined for a particular config value, to see if the override is set.
> On 2 Nov 2019, at 5:46 PM, Peter Lord <plord12 at gmail.com <mailto:plord12 at gmail.com>> wrote:
> Hi All,
> In trying to get my UK Kona Electric working I've realised that in the eNiro code we need to distinguish between :
> * Kia eNero and Hyundai Kona ( console odometer is different PID location )
> * Country ( console odometer can be in Miles or Kilometres )
> * Left hand drive and right hand drive ( door PID's are associated with driver position not fixed left/right )
> I'm wondering whats the best way to do this.
> I believe the VIN number can tell us the first one - Hyundai is KMH and Kia KN, so the odometer code could
> look at the VIN number to choose where to extract the odometer info.
> However I'm not sure on the others. I can't tell if the VIN number gives this level of detail.
> My UK Kona ( right hand dive, uses miles ) VIN starts with KMHK581GUKU - but I've not found a definitive way to
> fully decode the VIN for eNiro and Kona Electric.
> I guess the other option is to add some car specific features.
> Any ideas ?
> Thanks,
> Pete
> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191104/68752dad/attachment-0001.html>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191104/68752dad/attachment-0001.png>
