[Ovmsdev] Distinguishing between eNiro and Kona
Mon Nov 4 13:33:30 HKT 2019
In general, it is best to differentiate different models/features based on CAN bus traffic - although I realise that can be non-trivial at least when starting a project and only your own car’s logs to see. Perhaps others can collaborate with log captures from different variants?
You can have a config-based override / setting for this. It is easy to check IsDefined for a particular config value, to see if the override is set.
> On 2 Nov 2019, at 5:46 PM, Peter Lord <plord12 at gmail.com> wrote:
> Hi All,
> In trying to get my UK Kona Electric working I've realised that in the eNiro code we need to distinguish between :
> * Kia eNero and Hyundai Kona ( console odometer is different PID location )
> * Country ( console odometer can be in Miles or Kilometres )
> * Left hand drive and right hand drive ( door PID's are associated with driver position not fixed left/right )
> I'm wondering whats the best way to do this.
> I believe the VIN number can tell us the first one - Hyundai is KMH and Kia KN, so the odometer code could
> look at the VIN number to choose where to extract the odometer info.
> However I'm not sure on the others.  I can't tell if the VIN number gives this level of detail.
> My UK Kona ( right hand dive, uses miles ) VIN starts with KMHK581GUKU - but I've not found a definitive way to
> fully decode the VIN for eNiro and Kona Electric.
> I guess the other option is to add some car specific features.
> Any ideas ?
> Thanks,
> Pete
