[Ovmsdev] ESP32 CAN controller hardware bug / interrupt issue
Fri Nov 1 19:35:04 HKT 2019
An unusual fast reply from Espressif. They basically declared it to be a feature…
https://github.com/espressif/esp-idf/issues/4276#issuecomment-548753085
Am 01.11.19 um 10:34 schrieb Michael Balzer:
> I've submitted an issue to Espressif on this:
> It would be nice if I could reproduce the effect using some standard hardware.
> I've ordered some of those combined ESP32 + OLED units, but don't have any CAN transceivers I could hook up to them.
> Maybe the info I've provided is sufficient for Espressif to investigate.
> Am 31.10.19 um 22:24 schrieb Michael Balzer:
>> Second finding & commit:
>> TL;DR:
>> * ESP32 CAN controller is broken, delivers trashed & duplicated RX frames
>> * we need to optimize interrupt latency
>> Users have been reporting occasional false BMS readings on the Twizy for more than a year.
>> The error always trashed the reading of voltage #10 and/or temperature #8, so I initially
>> thought that must be a variant of the SPIRAM/cache bug.
>> But the SPIRAM fix didn't help, and the bug still occured with all BMS data in internal
>> RAM. The issue correlated with high load situations and the SIMCOM UART issue. On testing the
>> latest changes by Marko, my car module began showing that issue regularly, so I could take a
>> closer look. It turned out the wrong data came from the CAN bus. Checking with a CAN logger
>> didn't show any wrong data on the bus.
>> So I scanned our CAN driver for potential issues, found & solved some (even a serious
>> race condition) but that didn't fix it. I then added debug dumps of all frames read, dug
>> into the SJA1000 spec sheet and found this:
>> The SJA1000 RX FIFO has a capacity of 64 bytes. It's supposed to work as a ring buffer,
>> with frames wrapping around as necessary. If no space is left in the FIFO for a new frame
>> coming in, that frame should be discarded completely, not counted, just the overflow
>> indicator should be set & the according interrupt be generated.
>> Reality differs. The frame causing the overflow is added to the FIFO partially. It's also
>> counted both in the RMC register and indicated by RBS as a valid frame when retrieving
>> the FIFO contents. The read buffer delivers the partial frame + some trashed bytes up
>> to the nominal frame length.
>> In the BMS frame sequence it would normally trash bytes 7 & 8 on the sixth frame of length
>> 8 in a sequence. A standard frame needs a 3 byte header + the data bytes in the FIFO, so
>> 6 frames would add up to 66 bytes => 64 + 2 trash. The first trash byte normally is "08",
>> the second "84" or "2a" or sometimes "ab", possibly some internal SJA1000 data.
>> Better yet, if you rely on the indicators of the SJA1000 when reading the FIFO, the
>> SJA1000 will repeat the first frame within the FIFO after the invalid frame. Mostly
>> once or twice, and sometimes 7 times or more:
>> inv_msg: framecnt=13, invindex=6
>> inv_msg: 55 01 00 00 07 98 50 54 54 20 00 6e | 4..?........U.....PTT .n
>> inv_msg: 24 04 00 00 11 40 10 22 37 55 00 37 | 4..?........$.... at ."7U.7
>> inv_msg: 25 04 00 00 0a 1b 44 ff fe 4e 01 26 | 4..?........%.....D..N.&
>> inv_msg: 54 05 00 00 37 37 37 37 37 37 37 00 | 4..?........T...7777777.
>> inv_msg: 56 05 00 00 31 63 14 31 53 14 31 4a | 4..?........V...1c.1S.1J
>> inv_msg: 57 05 00 00 31 43 14 31 53 15 *08 2a* | 4..?........W...1C.1S..*
>> ^^^^^ trashed bytes
>> … followed by 7 repetitions of the first frame:
>> If you had occasional strange false readings leading to strange effects, this
>> may be the explanation. Note: the SJA1000 FIFO bug may need specific circumstance
>> to occur in addition to the overflow, maybe the overflow happening on a specific
>> byte position in the FIFO -- I haven't tried to determine that.
>> I've tried clearing the overflow ASAP, looping on the IR indicator and looping
>> on the RMC, the fault is always the same. The workaround I've now done is adding
>> up the message lengths read during a FIFO run and discard all frames exceeding
>> the 64 byte border. Not pretty, but functional.
>> That keeps the trashed frames from being forwarded to the OVMS application level.
>> As with the SIMCOM UART, these overflows wouldn't happen if the interrupt handler
>> would react fast enough. It seems we've got a general interrupt latency issue.
>> And just as with the SIMCOM I saw a reduction of overflows when allocating the
>> CAN IRQ on core #0, another one with raising the IRQ level to 3, so that's
>> also part of my commit.
>> The esp-idf CAN driver apparently has the same issue even in the latest release,
>> I'll contact the author about this or post another issue to Espressif.
>> So our interrupt allocation is now:
>> Task Run# Lvl ISR# Usage Source
>> - 0 1 0 RTC Core ETS_RTC_CORE_INTR_SOURCE
>> esp_timer 0 1 0 RTOS esp_timer ETS_TIMER2_INTR_SOURCE
>> ipc0 0 1 0 RTOS Scheduler Core0 ETS_FROM_CPU_INTR0_SOURCE
>> ipc1 1 1 1 RTOS Scheduler Core1 ETS_FROM_CPU_INTR1_SOURCE
>> main 0 1 0 RTOS Watchdog ETS_TG0_WDT_LEVEL_INTR_SOURCE
>> OVMS Events 1 1 1 Peripherals (GPIO ISR) ETS_GPIO_INTR_SOURCE
>> OVMS Events 1 1 1 MAX7317 (spi_nodma) ETS_SPI3_INTR_SOURCE
>> *esp32can init 0 3 0 ESP32 CAN ETS_CAN_INTR_SOURCE**
>> **OVMS SIMCOM 0 2 0 SIMCOM UART ETS_UART1_INTR_SOURCE*
>> OVMS Events 1 1 1 USB console (UART) ETS_UART0_INTR_SOURCE
>> OVMS Events 1 1 1 SD card ETS_SDIO_HOST_INTR_SOURCE
>> I think we need to find the source of the interrupt latency and/or find some
>> better scheme to distribute the tasks & interrupts over the cores.
>> I still don't know why core #1 already got an issue with just our 6 interrupts.
>> This may be related to the SPIRAM fix adding overhead, but I've seen the FIFO
>> overflows before applying the fix, and the CAN issue also has been present for
>> over a year.
>> My working hypothesis is some task/driver disabling interrupts for too often
>> / too long, or non-IRAM ISRs getting delayed for too often / too long. And it
>> seems this is an issue especially on core #1.
>> Please verify & comment.
>> PS: a little side mystery: the netmanager task starts with priority 5, then
>> gets raised to 22 (probably a mutex priority inheritance), but never gets
>> lowered back to 5 afterwards. A FreeRTOS bug?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191101/aa39ca48/attachment-0001.html>
