[Ovmsdev] ESP32 CAN controller hardware bug / interrupt issue
Fri Nov 1 05:24:01 HKT 2019
Second finding & commit:
TL;DR:
  * ESP32 CAN controller is broken, delivers trashed & duplicated RX frames
  * we need to optimize interrupt latency
Users have been reporting occasional false BMS readings on the Twizy for more than a year.
The error always trashed the reading of voltage #10 and/or temperature #8, so I initially
thought that must be a variant of the SPIRAM/cache bug.
But the SPIRAM fix didn't help, and the bug still occured with all BMS data in internal
RAM. The issue correlated with high load situations and the SIMCOM UART issue. On testing the
latest changes by Marko, my car module began showing that issue regularly, so I could take a
closer look. It turned out the wrong data came from the CAN bus. Checking with a CAN logger
didn't show any wrong data on the bus.
So I scanned our CAN driver for potential issues, found & solved some (even a serious
race condition) but that didn't fix it. I then added debug dumps of all frames read, dug
into the SJA1000 spec sheet and found this:
The SJA1000 RX FIFO has a capacity of 64 bytes. It's supposed to work as a ring buffer,
with frames wrapping around as necessary. If no space is left in the FIFO for a new frame
coming in, that frame should be discarded completely, not counted, just the overflow
indicator should be set & the according interrupt be generated.
Reality differs. The frame causing the overflow is added to the FIFO partially. It's also
counted both in the RMC register and indicated by RBS as a valid frame when retrieving
the FIFO contents. The read buffer delivers the partial frame + some trashed bytes up
to the nominal frame length.
In the BMS frame sequence it would normally trash bytes 7 & 8 on the sixth frame of length
8 in a sequence. A standard frame needs a 3 byte header + the data bytes in the FIFO, so
6 frames would add up to 66 bytes => 64 + 2 trash. The first trash byte normally is "08",
the second "84" or "2a" or sometimes "ab", possibly some internal SJA1000 data.
Better yet, if you rely on the indicators of the SJA1000 when reading the FIFO, the
SJA1000 will repeat the first frame within the FIFO after the invalid frame. Mostly
once or twice, and sometimes 7 times or more:
inv_msg: framecnt=13, invindex=6
inv_msg: 55 01 00 00 07 98 50 54 54 20 00 6e | 4..?........U.....PTT .n
inv_msg: 24 04 00 00 11 40 10 22 37 55 00 37 | 4..?........$.... at ."7U.7
inv_msg: 25 04 00 00 0a 1b 44 ff fe 4e 01 26 | 4..?........%.....D..N.&
inv_msg: 54 05 00 00 37 37 37 37 37 37 37 00 | 4..?........T...7777777.
inv_msg: 56 05 00 00 31 63 14 31 53 14 31 4a | 4..?........V...1c.1S.1J
inv_msg: 57 05 00 00 31 43 14 31 53 15 *08 2a* | 4..?........W...1C.1S..*
                                       ^^^^^ trashed bytes
… followed by 7 repetitions of the first frame:
If you had occasional strange false readings leading to strange effects, this
may be the explanation. Note: the SJA1000 FIFO bug may need specific circumstance
to occur in addition to the overflow, maybe the overflow happening on a specific
byte position in the FIFO -- I haven't tried to determine that.
I've tried clearing the overflow ASAP, looping on the IR indicator and looping
on the RMC, the fault is always the same. The workaround I've now done is adding
up the message lengths read during a FIFO run and discard all frames exceeding
the 64 byte border. Not pretty, but functional.
That keeps the trashed frames from being forwarded to the OVMS application level.
As with the SIMCOM UART, these overflows wouldn't happen if the interrupt handler
would react fast enough. It seems we've got a general interrupt latency issue.
And just as with the SIMCOM I saw a reduction of overflows when allocating the
CAN IRQ on core #0, another one with raising the IRQ level to 3, so that's
also part of my commit.
The esp-idf CAN driver apparently has the same issue even in the latest release,
I'll contact the author about this or post another issue to Espressif.
So our interrupt allocation is now:
Task           Run#  Lvl  ISR#  Usage                    Source
-              0     1    0     RTC Core                 ETS_RTC_CORE_INTR_SOURCE
esp_timer      0     1    0     RTOS esp_timer           ETS_TIMER2_INTR_SOURCE
ipc0           0     1    0     RTOS Scheduler Core0     ETS_FROM_CPU_INTR0_SOURCE
ipc1           1     1    1     RTOS Scheduler Core1     ETS_FROM_CPU_INTR1_SOURCE
main           0     1    0     RTOS Watchdog            ETS_TG0_WDT_LEVEL_INTR_SOURCE
OVMS Events    1     1    1     Peripherals (GPIO ISR)   ETS_GPIO_INTR_SOURCE
OVMS Events    1     1    1     MAX7317 (spi_nodma)      ETS_SPI3_INTR_SOURCE
*esp32can init  0     3    0     ESP32 CAN                ETS_CAN_INTR_SOURCE**
**OVMS SIMCOM    0     2    0     SIMCOM UART              ETS_UART1_INTR_SOURCE*
OVMS Events    1     1    1     USB console (UART)       ETS_UART0_INTR_SOURCE
OVMS Events    1     1    1     SD card                  ETS_SDIO_HOST_INTR_SOURCE
I think we need to find the source of the interrupt latency and/or find some
better scheme to distribute the tasks & interrupts over the cores.
I still don't know why core #1 already got an issue with just our 6 interrupts.
This may be related to the SPIRAM fix adding overhead, but I've seen the FIFO
overflows before applying the fix, and the CAN issue also has been present for
over a year.
My working hypothesis is some task/driver disabling interrupts for too often
/ too long, or non-IRAM ISRs getting delayed for too often / too long. And it
seems this is an issue especially on core #1.
Please verify & comment.
PS: a little side mystery: the netmanager task starts with priority 5, then
gets raised to 22 (probably a mutex priority inheritance), but never gets
lowered back to 5 afterwards. A FreeRTOS bug?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191031/69388d37/attachment.html>
