[Ovmsdev] SIMCOM UART interrupt issue & optimization
Fri Nov 1 05:19:49 HKT 2019
Everyone,
I've pushed another optimization for the SIMCOM component that reduces the UART hardware
FIFO overflows (https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/274)
to nearly zero by changing core associations.
TL;DR:
* you also should apply the sdkconfig changes from the commit
* we need to optimize interrupt latency
Analyzing our current core usage I found we've been running nearly all interrupt handlers on
core #1. That's because interrupts are bound to the core that allocates them, and after system
init, the housekeeper created all peripheral components on core #1.
This has been our interrupt allocation up to now:
Task Run# Lvl ISR# Usage Source
- 0 1 0 RTC Core ETS_RTC_CORE_INTR_SOURCE
esp_timer 0 1 0 RTOS esp_timer ETS_TIMER2_INTR_SOURCE
ipc0 0 1 0 RTOS Scheduler Core0 ETS_FROM_CPU_INTR0_SOURCE
ipc1 1 1 1 RTOS Scheduler Core1 ETS_FROM_CPU_INTR1_SOURCE
main 0 1 0 RTOS Watchdog ETS_TG0_WDT_LEVEL_INTR_SOURCE
OVMS Events 1 1 1 Peripherals (GPIO ISR) ETS_GPIO_INTR_SOURCE
OVMS Events 1 1 1 MAX7317 (spi_nodma) ETS_SPI3_INTR_SOURCE
OVMS Events 1 1 1 ESP32 CAN ETS_CAN_INTR_SOURCE
OVMS Events 1 1 1 SIMCOM UART ETS_UART1_INTR_SOURCE
OVMS Events 1 1 1 USB console (UART) ETS_UART0_INTR_SOURCE
OVMS Events 1 1 1 SD card ETS_SDIO_HOST_INTR_SOURCE
I had some advances on the FIFO overflows by allocating a level 3 interrupt for the SIMCOM UART,
but not much. I then tried moving the SIMCOM interrupt handler to core #0, and that immediately
reduced the overflows drastically -- most of the time.
I read through the Espressif forums and issues on interrupt latency optimization and found a
precious hint here: https://www.esp32.com/viewtopic.php?t=11462#p46437
/"Finally, by default the LWIP task is allowed to run on either core, and will sometimes take a//
//spinlock which requires disabling interrupts. Try pinning this task to CPU 0, only"/
I did so, and the FIFO overflows disappeared completely on my bench. In my car there still
are some, but very few. I also tested pinning LWIP to core #1, that also worked and may be
an alternative.
I then searched for more config candidates affecting interrupt performance and also disabled
the interrupt backtrace feature. That saves just 4 instructions on interrupt entry, so has
little effect and can be re-enabled in case we need it.
I've reduced the UART IRQ level to 2 again as a support for my second finding regarding
the CAN controller, will describe that in the next post.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191031/500ffc8a/attachment-0001.html>
