[Ovmsdev] OVMS v3 v3.2.002 Over-the-Air firmware update
    Stephen Casner
    casner at acm.org
    Tue May 28 13:36:49 HKT 2019
Mark,
Thanks, that explains it.  I had forgotten that I had enabled
auto-update at 0300; since the timezone setting appears to be GMT,
that matches the hour when I received the notifications.  I should not
have auto-update enabled since I am running a current build of my own:
  Version: 3.2.001-18-gac0ae29b-dirty/ota_1/main (build idf
  v3.1-dev-2835-g151269458-dirty May 23 2019 17:16:23)
I'm not sure why the download would have failed, though.  I installed
a separate access point in my garage so that OVMS now has good wifi
connectivity.
On Tue, 28 May 2019, Mark Webb-Johnson wrote:
> Steve,
> I’ve seen that in the past where the module had trouble downloading the firmware. Every ten minutes, in the hour you set it to download at, it will check what is available and if I new version is available, it will notify:
> New OTA firmware XXX is available for download
> It will then try to prepare the flash partition, download, and reboot into that. If everything was successful, just before reboot it will notify:
> OTA firmware XXX has been updated (OVMS will restart)
> So, if you are getting a notification every ten minutes (six in the hour), saying new firmware is available, the most likely cause is that it can’t download and install the new firmware.
> > On 28 May 2019, at 11:45 AM, Stephen Casner <casner at acm.org> wrote:
> > This evening I have received 6 notifications (so far) from the iOS app
> > telling me that this new release is available.  I have properly
> > dismissed each of the notifications, so it is not just a repeat for
> > lack of acknowledgement.  Is something broken?
> >                                                        -- Steve
