[Ovmsdev] Vehicle Sub-Modules
Tue May 28 03:14:00 HKT 2019
The "projects" board really doesn't help in organizing vehicle contributors or support. A waste of time.
I think pulling in changes unreviewed wouldn't be good. We've got some inexperienced contributors who can use a little review and guidance. We also can see
where the framework needs more documentation or rules.
I never felt any lack of ownership when working on the system. In the beginning I worked on my own fork and felt free to do whatever I wanted with it. It was
especially helpful being able to modify the framework in my fork and include framework changes into my pull requests. That made me feel being part of the whole
project from the beginning instead of just writing a plugin.
> At the moment, the vehicle modules are the most troublesome part of the system. We get support calls / emails for these, but no easy way to answer. I would really like to find a way to ease and incentivise the development of vehicle modules.
Btw, github forks have the "issues" menu disabled only by default, that's just a config. If you enable the issues menu on a fork, you're getting your own issues
database. But I wouldn't like to get user support requests as "issues".
I think the main issue here is routing vehicle users to vehicle developers. It's not easy to figure out who is currently in charge for a vehicle adaption and
how to contact them / file some issue or support request.
How about adding a vehicle contact section to the wiki or main README.md and mirror that on our websites? That way we're giving credit to contributors and solve
the routing problem.
Am 27.05.19 um 17:24 schrieb Greg D.:
> Hi Mark,
> I think the process you used with me in the development of the OBD2ECU
> process worked pretty well.  I've always been the owner of the code, but
> it was based on an initial template for system services (CAN access, CLI
> processing, etc.) that you provided, and pull requests got more or less
> of a review before the actual pull depending on circumstance.
> I don't feel any less of an owner than if the code were in a separate
> git repository.  A lot of that is due to how you manage the project, not
> where the bits are stored.  In the end, it's all compiled into one
> object module, and I don't think that part of the process will (or
> should) change.
> Greg
> p.s.  To the documentation task, please everyone don't forget to update
> the table at the end of the user guide for what metrics are available to
> the OBD2ECU translator, based on vehicle type.  I think we're missing
> whole columns for new vehicles, but haven't been following the vehicle
> additions closely enough to know for sure..
> Mark Webb-Johnson wrote:
>> I view them as modules, not really standalone projects or libraries. Kind of like all those modular components in systems like GEM, HomeBridge, logstash, etc. They won’t work outside their given ecosystem.
>> Just trying to think of a way of making it easier to get involved / write vehicle support modules (and trying to encourage fitting in with the existing framework, rather than modifying it).
>> Getting rid of having to merge pull requests is one motivation, but it is really more towards giving a sense of ownership to the vehicle module maintainer. He/she can commit as they work on the module, and both he/she and the main project simply pull in whatever they have at the time of build.
>>> On 27 May 2019, at 7:55 AM, Stephen Casner <casner at acm.org> wrote:
>>> In the cases I'm aware of, submodules are independent building blocks
>>> used by other projects.  Our vehicle modules have many dependencies
>>> upon the core of the OVMS system.  I'm not sure if that works.
>>> Also, if you want to make standard releases that support all the
>>> vehicles then you would be dependent upon the separate project owners
>>> to get their submodules ready.
>>> I assume that your motivation for considering this change is to avoid
>>> the load of be merging pull requests.  I acknowledge the extra work,
>>> but in my view that extra level of filtering is often a good thing.
>>>                                                        -- Steve
>>> On Sun, 26 May 2019, Mark Webb-Johnson wrote:
>>>> Given that the vehicle modules in v3 are pretty independent, and don't seem to require any changes to the core code to implement (other than a Kconfig section, and a sub-directory in 'components'), I'm considering a structural change.
>>>> The proposal is to make each vehicle an independent GitHub repository, and to use the git submodule functionality to bring them in. The advantage there is that those projects can be split off and maintained by different people. Project owners, looking after their own vehicle types, could directly commit to their own vehicle modules, without requiring this to be centrally managed.
>>>> What do people think? Is that a sensible way of doing this?
>>>> Regards, Mark.
>>>> OvmsDev mailing list
