    Stephen Casner
    casner at acm.org
    Fri May 24 09:16:58 HKT 2019
Finally, after some travel and other delays, getting back to this
question of the false flatbed alarms.  I've started logging with:
OVMS# can log crtd /sd/location.crtd 1:100
Plus I've hacked the filter function in canlog to save only those
frames with data.u8[0] = 83, 84 or 85, so the total is about 5MB per
day.  I can leave that running for a while.
On Tue, 2 Apr 2019, Mark Webb-Johnson wrote:
> The 'can log crtd ...' would be fine. That logs directly to disk, and would be the easiest for a replay (to try to recreate the problem).
> I don't think there is any easy way to pre-filter for B1, so the whole of ID 0x100 would be fine.
> If we can get a full crtd trace around the time of the problem, then get told 'I got a text notification of vehicle on flatbed at 7:50pm on 4th', we can narrow it down and replay just that part.
> > On 2 Apr 2019, at 2:53 PM, Stephen Casner <casner at acm.org> wrote:
> > I think Mark is requesting "can log trace" rather than "can log
> > crtd".  For the former you have already implemented rotation of
> > the log files based on max size as configurable in the web UI, right?
> >                                                        -- Steve
> > On Tue, 2 Apr 2019, Michael Balzer wrote:
> >> I've used the trace command to log high volume CAN traffic, that's no problem (at least with a recent module having the SD speed fix).
> >> The tracing just lacks a file rotation, but that shouldn't be hard to add.
> >> Regards,
> >> Michael
> >> Am 02.04.19 um 04:58 schrieb Mark Webb-Johnson:
> >>> I am not sure if the SD is fast enough to store can log files. It would not be too hard to start/stop logging in javascript (without code changes).
> >>> Regards, Mark.
> >>>> On 2 Apr 2019, at 10:28 AM, Stephen Casner <casner at acm.org> wrote:
> >>>> Well, for my car this event has occurred twice in a few months, so the
> >>>> idea of running a CAN bus dump in a wifi session all the time is not
> >>>> practical.  What we would need would be a CAN bus dump to rotating
> >>>> files, like the error message logging can do.
> >>>>                                                       -- Steve
> >>>>> Steve,
> >>>>>> What should I look for when this false alarm occurs?  Is it likely
> >>>>>> that the alarm is issued when stable GPS operation is restored, so
> >>>>>> what I really would need to see is a log of conditions before the
> >>>>>> alarm?
> >>>>> What we would ideally need would be at the time of the issue:
> >>>>> metric list v.p
> >>>>> CAN bus dump (can1) ID #100, B1=0x83,0x84,0x85
> >>>>> I appreciate that is hard. Perhaps just leave a CAN bus dump running
> >>>>> over wifi throughout the event? You could leave that running for
> >>>>> hours. We could then replay that back through a box to recreate the
> >>>>> issue.
> >>>>>> And now that I have issued some messages in the app, how do I switch
> >>>>>> back to other functions?  Is there a way to make the keyboard drop and
> >>>>>> then find the buttons at the bottom of the screen?  (I realize that
> >>>>>> restarting the app would be a solution.)
> >>>>> Just click on the screen, away from the keyboard.
> >>>>> Regards, Mark.
> >>>>>> On 2 Apr 2019, at 5:47 AM, Stephen Casner <casner at acm.org> wrote:
> >>>>>> Mark,
> >>>>>> The false alarm occured again a few minutes ago.  I wanted to use the
> >>>>>> web shell UI to check some status, but using the new messages feature
> >>>>>> of the iPhone app I found the wifi was wedged again.  After I turned
> >>>>>> wifi off and then back to client mode I would log in from the web
> >>>>>> again.  I issued a location status command that indicated good lock.
> >>>>>> alarm?
> >>>>>>                                                      -- Steve
> >>>>>> On Mon, 1 Apr 2019, Mark Webb-Johnson wrote:
> >>>>>>> I don't see this on the Model S vehicle.
> >>>>>>> I suspect the issue is not handling GPS lock indicator correctly
> >>>>>>> in the vehicle modules. For the roadster, we use ID#100, B1=0x85
> >>>>>>> (GPS direction and altitude), B2==1 to control this, but that was
> >>>>>>> always a 'best guess' without much data to back it up.
> >>>>>>> Regards, Mark.
> >>>>>>>> On 31 Mar 2019, at 11:12 PM, Stephen Casner <casner at acm.org> wrote:
> >>>>>>>> Mark,
> >>>>>>>> This message reminds me to mention that both Timothy Rodgers and I
> >>>>>>>> have received false alarm car-theft notifications from OVMS.  Have
> >>>>>>>> you?  I presume these are caused by temporary inaccuracy in the GPS
> >>>>>>>> signal.
> >>>>>>>>                                                     -- Steve
