[Ovmsdev] Support for Kia e-Niro
Geir Øyvind Vælidalo
geir at validalo.net
Sat Mar 2 04:18:06 HKT 2019
I’ll put it in my todo-list 🙂
The user manual might also need an update.
Geir
> 1. mar. 2019 kl. 19:10 skrev Greg D. <gregd2350 at gmail.com>:
> Yea! A new car... Don't forget to list the metrics that are supported in the appendix table, adding a new column for new cars as needed. (Note also to anyone who may have added or changed existing car metrics since the table was created.)
> Thanks,
> Greg
> Geir Øyvind Vælidalo wrote:
>> Hi,
>> I’m working on support for the Kia e-Niro, so as a part of that I’ve added images for the e-Niro in the App.
>> Mark, it would be great if you could merge my pull request to the iOS-app 🙂
>> Also, maybe someone could add the images to the Android app too?
>> A first version for the OVMS module will be coming soon. I hope 😜
>> There was an issue with polling using Extended 16-bit PIDS. There were no support for flow control and multiple response frames, so I’ve added that, similar to 8-bit PIDS. I see that it is used in ThinkCity and Volt/Ampera. Did it work there without flow control?
>> Best regards,
>> Geir
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190301/a3d977f7/attachment.htm>
