[Ovmsdev] Support for Kia e-Niro
Sat Mar 2 19:42:43 HKT 2019
Geir,
Sounds great.
I have merged the images into the App, so they will get included in the next master build.
> On 1 Mar 2019, at 9:26 PM, Geir Øyvind Vælidalo <geir at validalo.net> wrote:
> Hi,
> I’m working on support for the Kia e-Niro, so as a part of that I’ve added images for the e-Niro in the App.
> Mark, it would be great if you could merge my pull request to the iOS-app 🙂
> Also, maybe someone could add the images to the Android app too?
> A first version for the OVMS module will be coming soon. I hope 😜
> There was an issue with polling using Extended 16-bit PIDS. There were no support for flow control and multiple response frames, so I’ve added that, similar to 8-bit PIDS. I see that it is used in ThinkCity and Volt/Ampera. Did it work there without flow control?
> Best regards,
> Geir
