[Ovmsdev] iOS-App
Mark Webb-Johnson mark at openvehicles.com
Mon Jun 24 16:04:38 HKT 2019
Martin,
Welcome to the list.
Not sure what problem you are having with your @hofgesang.de mailing address. I see one message on 2019-06-23 13:17:59 UTC that seemed to have been delivered (mailing list confirmation), but nothing else.
Regarding the 4th generation ED/EQ support, that sounds great. If at all possible, please implement this by extending the existing Smart ED module, with a switch to control. This can either be a configuration option, or determined automatically via can bus traffic.
For iPhone, the server setting is in the iOS Settings App (the gray gears App on the home screen of your phone), not in the ovms app. You will find a “Open Vehicles” area in that.
> On 24 Jun 2019, at 3:56 PM, Martin Hofgesang <martin.hofgesang at gmx.de> wrote:
> Hi all,
> first of all I want to say hello to you all, I am Martin, I started some days ago the work on a new vehicle for OVMS, the Smart ED/EQ (4th Generation), which has unfortunately other CAN-Ids than the existing module for Smart ED.
> Thomas who last changed the ED-module helped by doing the programmer stuff and I'm currently investigating the CAN-Ids and the information my EQ will give us through CAN-Bus.
> To test the module stability and use it in a normal way I would enjoy using the iPhone-App, but in the app I miss a setting for the server URL like it is in the Android app.
> Do I guess right, that the server setting is fixed to ovms.openvehicles.com and I can't use the german server from Dexter?
> How can I get an account as the openvehicles website and mailinglist is refusing to work with my mailadress ovms (a) hofgesang.de which I normally use for this project and would like to use here.
> Thanks & Regards
> Martin
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190624/a2cd3a7c/attachment.htm>
