Tue Jun 11 14:37:36 HKT 2019
This really should be unified, and probably not too hard to do. Crazy to have two so similar frameworks. I think we can just have one virtual class for converting CAN frames to/from other formats, and then implementations for CRTD, PCAP, etc.
I do remember that last time I looked at this, canlog used CAN_LogMsg_t, and candump used CAN_frame_t (with CAN_LogMsg_t having some other fields for logging statistics, etc), and that made it non-trivial. Perhaps canlog should be built on top of candump?
I will have a look at it.
> On 6 Jun 2019, at 4:06 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Steve,
> Mark quoted from the RE tools candump_crtd class, which has its own crtd formatter.
> For the canlog framework I currently get the timestamp from esp_log_timestamp(). Should be easy to change that to gettimeofday().
> Am 05.06.19 um 18:39 schrieb Stephen Casner:
>> Mark,
>> If by "unix julian time" you mean a timestamp like 1559751698 (the
>> time as I write this), than that is not what Greg and I have observed
>> in the CRTD logs. Here are the first lines in our files:
>> 151766.574 CXX Info Type:crtd; Path:'/sd/gps.crtd'; Filter:1:100-100; Vehicle:TR2N;
>> 383603.293 CXX Info Type:crtd; Path:'/sd/location.crtd'; Filter:1:100-100; Vehicle:TR1N;
>> Yet OVMS does have the current time from NTP:
>> OVMS# time
>> Time Zone:
>> UTC Time: 2019-06-05 16:35:45 UTC
>> Local Time: 2019-06-05 16:35:45 GMT
>> Provider: ntp
>> PROVIDER STRATUM UPDATE TIME
>> *ntp 1 57 Wed Jun 5 16:35:44 2019
>> Who calls candump_crtd::get() with the timeval that goes into the
>> sprintf() you mention?
>> -- Steve
>> On Wed, 5 Jun 2019, Mark Webb-Johnson wrote:
>>> The CRTD timestamps should be unix julian time (not uptime). Produced by this:
>>> sprintf(m_buf,"%ld.%06ld %sR%s %0*X",
>>> time->tv_sec, time->tv_usec,
>>> busnumber,
>>> (frame->FIR.B.FF == CAN_frame_std) ? "11":"29",
>>> (frame->FIR.B.FF == CAN_frame_std) ? 3 : 8,
>>> frame->MsgID);
>>> Once module gets time from the vehicle (or gps), it should show the correct timestamps.
