[Ovmsdev] Rebooting
Sat Jun 8 18:25:41 HKT 2019
It shouldn't crash from GPS streaming though, so it would still make sense to share the logs.
Am 08.06.19 um 09:57 schrieb ovms:
> Thanks for the reply Michael. I suddenly remembered that I had set GPS stream to 1 in the app.
> I set GPS stream to 0 again and there is no longer a problem.
> Stein Arne
> On 2019-06-08 09:53, Michael Balzer <dexter at expeedo.de> wrote:
> Please check your logs at verbose level for details on the crash point.
> Am 08.06.19 um 09:12 schrieb ovms:
> Anyone who knows what happens here? It keeps rebooting.
> Last boot was 240 second(s) ago Time at boot: 2019-06-08 07:04:18 GMT This is reset #193 since last power cycle Detected boot reason: Crash (12/12)
> Crash counters: 193 total, 0 early Last crash: Alloca exception on core 0 Registers: PC : 0x4009251a PS : 0x00060834 A0 : 0x80090666 A1 : 0x3ffc8d90
> A2 : 0x3ffc9b64 A3 : 0x3ffc9528 A4 : 0x3ffc950c A5 : 0x00000001 A6 : 0x000000fe A7 : 0x3fa21d38 A8 : 0x3ffc9528 A9 : 0x00000018 A10 : 0x3ffc9528 A11 :
> 0x00000018 A12 : 0x3f40c407 A13 : 0x3f40c288 A14 : 0x000000fe A15 : 0x00000001 SAR : 0x00000004 EXCCAUSE: 0x00000005 EXCVADDR: 0x00000000 LBEG :
> 0x40099439 LEND : 0x40099449 LCOUNT : 0xffffffff Backtrace: 0x4009251a 0x40090663 0x4008ef17 0x4008ef89 0x40084693 0x40084781 0x401138de 0x401029af
> 0x400931c3 0x4009320b 0x40084179 0x400845b1 0x4000bec7 0x4019c70d 0x401a2342 0x40128887 0x40128947 0x4024bf49 0x400e7f19 0x400e7f7d 0x400e76b1
> 0x400f0dc9 0x4009117b 0x40128887 0x40128947 0x4024bf49 0x400e7f19 0x400e7f7d 0x400e76b1 0x400f0dc9 0x4009117b Version: 3.2.002-65-g02a07a2/ota_0/edge
> (build idf v3.1-dev-2835-g1512694 May 17 2019 00:00:19)
> Firmware: 3.2.002-65-g02a07a2/ota_0/edge (build idf v3.1-dev-2835-g1512694 May 17 2019 00:00:19) Running partition: ota_0 Boot partition: ota_0
> Factory image: 3.1.010-5-g00a770e1-dirty OTA_O image: 3.2.002-65-g02a07a2 OTA_1 image: 3.1.011-387-g739dbf49-dirty
> Stein Arne Sordal
> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
> _______________________________________________ OvmsDev mailing list OvmsDev at lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190608/f73ce633/attachment.htm>
