[Ovmsdev] Interrupts when hearing from digital radio station
Martin Hofgesang
martin.hofgesang at gmx.de
Fri Jun 28 13:36:02 HKT 2019
Hi,
Sorry to bother again with this topic, but I only wanted to ask if the new CE certified 3.2 module could make a difference here as I read it has some new filters on it?
Regards
Martin
Mit Hilfe von kathalytischen Konvertern gesendet.
> Am 24.06.2019 um 10:10 schrieb Martin Hofgesang <martin.hofgesang at gmx.de>:
> Hello all,
> When my OVMS-module is connected to my car and I am only doing some tracing of CAN-ids [1] I have trouble with hearing radio from radio station using DAB+.
> The radio frequently interrupts shortly when listening to such a radio station.
> When OVMS is disconnected everything is fine and I can listen to the radio without interrupts.
> I have to say, I did not mount my OVMS, so it lays on the floor or underneath the seat in my car, including the GPS- and GSM-antenna, I hope it will be better, when I mount the Antennas outside underneath the front trunk of my car (which has, luckily, a cover made from plastik).
> Did anyone have also problems with digital radio stations?
> Regards
> Martin
> [1] for example the command "can log crtd /sd/log/speed.txt 1:5d7"
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190628/15d5a1b1/attachment.html>
