[Ovmsdev] frequent crashes
Craig Leres
leres at xse.com
Thu Jun 27 06:31:07 HKT 2019
I've been running a v3.1 module in my Cadillac for a few weeks now and
recently realized that it crashes frequently. I see this on the status page:
Last boot was 12879 second(s) ago
Time at boot: 2019-06-26 11:31:51 PDT
This is reset #10 since last power cycle
Detected boot reason: Crash (8/14)
Crash counters: 8 total, 0 early
Last crash: abort() was called on core 0
Backtrace:
0x40096068 0x40096263 0x40115aa7 0x40232e95 0x4023312d 0x4023315d
0x40229d52 0x4022a780 0x40226576 0x402276d6 0x40227ad1
Version: 3.2.002-89-g0207c45e-dirty/ota_0/main (build idf
v3.1-dev-2835-g151269458 Jun 22 2019 14:12:19)
Firmware: 3.2.002-89-g0207c45e-dirty/ota_0/main (build idf
Running partition: ota_0
Boot partition: ota_0
Factory image: 3.2.002
OTA_O image: 3.2.002-89-g0207c45e-dirty
OTA_1 image: 3.2.002-89-g0207c45e-dirty
Which translates to:
+ xtensa-esp32-elf-addr2line -e build/ovms3.elf 0x40096068
0x40096263 0x40115aa7 0x40232e95 0x4023312d 0x4023315d 0x40229d52
/home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/esp32/panic.c:670
/home/jeroen/esp8266/esp32/newlib_xtensa-2.2.0-bin/newlib_xtensa-2.2.0/xtensa-esp32-elf/newlib/libc/stdlib/../../../.././newlib/libc/stdlib/assert.c:63
(discriminator 8)
/home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/lwip/core/ipv4/ip4.c:846
(discriminator 1)
/home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/lwip/core/ipv4/ip4.c:810
/home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/lwip/core/ipv4/ip4.c:787
/home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/lwip/core/tcp_out.c:1272
(discriminator 4)
/home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/lwip/core/tcp_out.c:1073
/home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/lwip/api/api_msg.c:1875
(discriminator 6)
(discriminator 6)
/home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/lwip/api/tcpip.c:474
I was beginning to think that my battery tender maintenance charger was
the cause but I disconnected it a few days ago.
Is this psram cache issue related or something else? I haven't written
much code yet and it doesn't do a lot, especially when the car is off.
Is there an easy way to poll the module for crash related info?
I never understood what the boot reason numbers were:
but I see now that there is a number for each core and are defined in
the esp-idf/components/esp32/include/rom/rtc.h:
typedef enum {
NO_MEAN = 0,
POWERON_RESET = 1, /**<1, Vbat power on reset*/
SW_RESET = 3, /**<3, Software reset digital core*/
OWDT_RESET = 4, /**<4, Legacy watch dog reset
digital core*/
DEEPSLEEP_RESET = 5, /**<3, Deep Sleep reset digital core*/
SDIO_RESET = 6, /**<6, Reset by SLC module, reset
digital core*/
TG0WDT_SYS_RESET = 7, /**<7, Timer Group0 Watch dog reset
digital core*/
TG1WDT_SYS_RESET = 8, /**<8, Timer Group1 Watch dog reset
digital core*/
RTCWDT_SYS_RESET = 9, /**<9, RTC Watch dog Reset digital
core*/
INTRUSION_RESET = 10, /**<10, Instrusion tested to reset
CPU*/
TGWDT_CPU_RESET = 11, /**<11, Time Group reset CPU*/
SW_CPU_RESET = 12, /**<12, Software reset CPU*/
RTCWDT_CPU_RESET = 13, /**<13, RTC Watch dog Reset CPU*/
EXT_CPU_RESET = 14, /**<14, for APP CPU, reseted by PRO
CPU*/
RTCWDT_BROWN_OUT_RESET = 15, /**<15, Reset when the vdd voltage
is not stable*/
RTCWDT_RTC_RESET = 16 /**<16, RTC Watch dog reset digital
core and rtc module*/
} RESET_REASON;
so my most recent reset was due to 8: "Timer Group1 Watch dog reset
digital core" (and the 14 is probably cpu0 resetting cpu1 when the watch
dog hit?) I am using Ticker10 based on Ticker1 code I saw in
vehicle_nissanleaf.cpp. But I get crashes even if I ifdef out that code out.
I've also attached a screen grab from my hologram.io account, I think
it's showing just how frequently the crashes are.
I could also eliminate my FreeBSD xtensa toolchain by doing a build
under ubuntu, would that be worthwhile?
Craig
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190626/43c822bb/attachment-0001.png>
