[Ovmsdev] v3.2 hardware schematics and PCB layout
Tue Jun 18 09:25:02 HKT 2019
> When will the new v3.2 modules hit fasttech.com?
US kits are in stock (and FCC approved kits will come later).
EU (CE certified) kits should be at fasttech next week. We will also courier to the new EU distributor (in UK) around the same time - probably easiest/fastest to order from them.
> On 18 Jun 2019, at 4:43 AM, Craig Leres <leres at xse.com> wrote:
> When will the new v3.2 modules hit fasttech.com? This weekend I figured out that while the low speed bus in my Corvette is J1850, the high speed is canbus and ovms can talk to the car without issue. (I feel a little silly because all of the information was in my head and it wasn't until I was hardwiring the CTS-V this weekend that I put it all together...)
> I also figured out that what disrupts the canbus in my CTS-V is configuring can1 to 1000 Kbps. It doesn't matter which mode is used, even CAN_MODE_LISTEN prevents normal module to module communications (which was somewhat surprising). Anyway I have it working with CAN_MODE_ACTIVE @ 500K.
> 		Craig
