[Ovmsdev] Can message flow reproduce
Tamás Kovács kommykt at gmail.com
Sun Jul 28 00:40:22 HKT 2019
now working if sending the following message from terminal/shell: "can can1
tx standard 761 02 21 01" and I get the requested message 😊
I add some line to the code:
case 0x762: // AH
      CAN_frame_t frame;
      if (d[0] == 16)
        // Request CAC...
        frame.origin = m_can1;
        frame.FIR.U = 0;
        frame.FIR.B.DLC = 8;
        frame.FIR.B.FF = CAN_frame_std;
        frame.MsgID = 0x761;
        frame.data.u8[0] = 0x30;
        frame.data.u8[1] = 0x08;
        frame.data.u8[2] = 0x0A;
        m_can1->Write(&frame);
      if(d[0] == 36)
          //battery max capacity
          StandardMetrics.ms_v_bat_cac->SetValue(((d[3]*256 + d[4]) /
10.0));
          // battery remain capacity
          xmi_v_bat_cac_rem->SetValue(((d[5]*256 + d[6]) / 10.0));
          //max charging kW
          xmi_v_bat_max_input->SetValue(d[7]/4);
      if(d[0] == 37)
          //max outpu kW
          xmi_v_bat_max_output->SetValue(d[1]/4);
    break;
Tamás Kovács <kommykt at gmail.com> ezt írta (időpont: 2019. júl. 25., Cs,
20:57):
> hi, Now i get a Lexia for Peugeot iOn and I get some useful data on can
> network, such as SOH and another metrics.
> if Lexia connected and I create a OVMS can log. I see the following data:
> 167913.526 1R11 761 2 21 1 FF FF FF FF FF
> 167913.536 1R11 762 10 2E 61 1 90 8F 1 79
> 167913.546 1R11 761 30 8 0A FF FF FF FF FF
> 167913.576 1R11 762 22 0A 4C 3 1 5E 1 5D
> 167913.596 1R11 762 23 1 2C 0 FA 0 FB 0
> 167913.606 1R11 762 24 0F 0F 1 5A 0 E8 A5
> 167913.636 1R11 762 26 64 0 0 0 0 0 0
> 167914.026 1R11 762 24 0F 0F 1 5A 0 E8 A5
> 167914.046 1R11 762 25 FE 0 0 1 78 75 7B
> 167914.056 1R11 762 26 64 0 0 0 0 0 0
> 167914.436 1R11 761 30 8 0A FF FF FF FF FF
> 167914.446 1R11 762 21 0 1 78 33 0D B3 4E
> 167914.476 1R11 762 23 1 2C 0 F9 0 FB 0
> 167914.496 1R11 762 24 0F 0F 1 5A 0 E8 A5
> 167914.876 1R11 761 2 21 1 FF FF FF FF FF
> 167914.876 1R11 762 10 2E 61 1 90 8F 1 79
> 167914.896 1R11 761 30 8 0A FF FF FF FF FF
> 167914.906 1R11 762 21 0 1 79 0 0D B3 4E
> 167914.926 1R11 762 22 0A 4C 3 1 5E 1 5D
> 167914.966 1R11 762 25 FE 0 0 1 79 75 7B
> 167914.986 1R11 762 26 64 0 0 0 0 0 0
> 167915.316 1R11 761 2 21 1 FF FF FF FF FF
> I searching on google and find the following things the Mitsubishi
> Outlander PHEV (
> http://www.myoutlanderphev.com/forum/viewtopic.php?f=10&t=1796) use the
> same PID-s.
> And many more useable metrics if I can resolve this communication with
> ECU-s
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190727/89cfac70/attachment.htm>
