[Ovmsdev] BUG? in v3.2.0-1 in vehicle_mitsubishi - flood of BMS-error msg
Thu Jul 11 20:16:40 HKT 2019
FYI: I’ve just found this bug while porting the ‘re serve’ to ‘can log … tcpserver’. It seems we are binding to :3000 (or wherever) when we start, but not unbinding (closing the socket) when we stop. That means starting then stopping leaves the port in a weird state (where we can see a connection, but not accept it). Also can’t start, stop, start properly.
I’ll commit the fix in the next hour or so.
> On 19 Jan 2019, at 9:34 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Should not be.
> Are you sure the ‘re’ is running?
>> On 19 Jan 2019, at 9:32 PM, Michael Eric Menk <mikeemenk at gmail.com <mailto:mikeemenk at gmail.com>> wrote:
>> On 19.01.2019 14:22, Tamás Kovács wrote:
>>> Then, on workstation:
>>>  - nc 192.168.4.1 3000 | tee log.crtd
>>> And the send me the log.crtd file.
>> Is the OVMS firewalled if it's connected as a WIFI client?
>>> nmap -P0 -p 3000  192.168.1.84
>>> Starting Nmap 7.60 ( https://nmap.org <https://nmap.org/> ) at 2019-01-19 14:31 CET
>>> Nmap scan report for 192.168.1.84
>>> Host is up.
>>> PORT     STATE    SERVICE
>>> 3000/tcp filtered ppp
>>> Nmap done: 1 IP address (1 host up) scanned in 2.12 seconds
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190711/6f98b402/attachment.html>
