[Ovmsdev] max7317 input read
Wed Jul 10 17:03:52 HKT 2019
- Where do you contact EGPIO5?
- Where do you get 3.3V? External +3.3V is only present if you're powering from 12V
Am 10.07.19 um 10:50 schrieb - -:
> I have the egpio5 (port 6) pin on GND.
> then in the shell: egpio input 6.
> then the gpio5 (port 6) pin to 3.3V.
> both return 0
> Regards Thomas
>> Michael Balzer <dexter at expeedo.de> hat am 10. Juli 2019 um 10:40 geschrieben:
>> Then you're now doing something wrong. Please describe your test setup.
>>  Regards,
>>  Michael
>>  Am 10.07.19 um 10:35 schrieb - -:
>>> Hi,
>>> i have test it, but it seems not to work.
>>>  it return always 0 when i put the egpio to GND or 3.3v
>>>> Michael Balzer dexter at expeedo.de hat am 9. Juli 2019 um 22:58 geschrieben:
>>>>  I did some tests myself, it turned out there was more to do here.
>>>>  First, the max7317 really needs 16 bits for every command. Second, the reads were done on the output level registers, inputs are mapped to bit fields in 0x0e & 0x0f. Third, the max7317 needs a deselect between the tx and the rx. No, really, I've tried even half duplex mode, the deselect really is necessary.
>>>>  Fix is pushed. I've also added an "egpio input" shell command.
>>>>  Regards,
>>>>  Michael
>>>> Am 09.07.19 um 20:00 schrieb Michael Balzer:
>>>>> Thomas,
>>>>>  there may be a bug in the max7317 component:
>>>>>> uint8_t max7317::Input(uint8_t port)
>>>>>>>>>>>>    uint8_t* p = m_spibus->spi_cmd(m_spi, buf, 1, 1, port + 0x80);
>>>>> According to the max7317 specsheet the read operation needs a second (dummy) byte. So this should be…
>>>>>>   uint8_t* p = m_spibus->spi_cmd(m_spi, buf, 1, 2, port + 0x80, 0);
>>>>> Please try & report.
>>>>>  Regards,
>>>>>  Michael
>>>>> Am 09.07.19 um 13:10 schrieb - -:
>>>>>> Hello,
>>>>>> How can I read inputs from max7317.
>>>>>>  when I try to log ESP_LOGD(TAG,"EGPIO5 input: %d", MyPeripherals->m_max7317->Input(MAX7317_EGPIO_5));
>>>>>> i get allways 0 when i put the egpio pin to GND or 3.3v
>>>>>>  do i somthing wrong or does it not work.
>>>>>> Regards Thomas
