[Ovmsdev] max7317 input read
Wed Jul 10 17:01:17 HKT 2019
The pin on the internal expansion connector, right? Not the external 26 pin expansion socket?
> On 10 Jul 2019, at 4:50 PM, - - <egon at heuer-humfeld.de> wrote:
> I have the egpio5 (port 6) pin on GND.
> then in the shell: egpio input 6.
> then the gpio5 (port 6) pin to 3.3V.
> both return 0
> Regards Thomas
>> Michael Balzer <dexter at expeedo.de> hat am 10. Juli 2019 um 10:40 geschrieben:
>> Then you're now doing something wrong. Please describe your test setup.
>> Am 10.07.19 um 10:35 schrieb - -:
>>> Hi,
>>> i have test it, but it seems not to work.
>>> it return always 0 when i put the egpio to GND or 3.3v
>>>> Michael Balzer dexter at expeedo.de hat am 9. Juli 2019 um 22:58 geschrieben:
>>>> I did some tests myself, it turned out there was more to do here.
>>>> First, the max7317 really needs 16 bits for every command. Second, the reads were done on the output level registers, inputs are mapped to bit fields in 0x0e & 0x0f. Third, the max7317 needs a deselect between the tx and the rx. No, really, I've tried even half duplex mode, the deselect really is necessary.
>>>> Fix is pushed. I've also added an "egpio input" shell command.
>>>> Regards,
>>>> Michael
>>>> Am 09.07.19 um 20:00 schrieb Michael Balzer:
>>>>> Thomas,
>>>>> there may be a bug in the max7317 component:
>>>>>> uint8_t max7317::Input(uint8_t port)
>>>>>>>>>>>>   uint8_t* p = m_spibus->spi_cmd(m_spi, buf, 1, 1, port + 0x80);
>>>>> According to the max7317 specsheet the read operation needs a second (dummy) byte. So this should be…
>>>>>>   uint8_t* p = m_spibus->spi_cmd(m_spi, buf, 1, 2, port + 0x80, 0);
>>>>> Please try & report.
>>>>> Regards,
>>>>> Michael
>>>>> Am 09.07.19 um 13:10 schrieb - -:
>>>>>> Hello,
>>>>>> How can I read inputs from max7317.
>>>>>> when I try to log ESP_LOGD(TAG,"EGPIO5 input: %d", MyPeripherals->m_max7317->Input(MAX7317_EGPIO_5));
>>>>>> i get allways 0 when i put the egpio pin to GND or 3.3v
>>>>>> do i somthing wrong or does it not work.
>>>>>> Regards Thomas
