[Ovmsdev] max7317 input read
Wed Jul 10 16:40:15 HKT 2019
Then you're now doing something wrong. Please describe your test setup.
Am 10.07.19 um 10:35 schrieb - -:
> Hi,
> i have test it, but it seems not to work.
> it return always 0 when i put the egpio to GND or 3.3v
>> Michael Balzer <dexter at expeedo.de> hat am 9. Juli 2019 um 22:58 geschrieben:
>> I did some tests myself, it turned out there was more to do here.
>> First, the max7317 really needs 16 bits for every command. Second, the reads were done on the output level registers, inputs are mapped to
>> bit fields in 0x0e & 0x0f. Third, the max7317 needs a deselect between the tx and the rx. No, really, I've tried even half duplex mode, the
>> deselect really is necessary.
>> Fix is pushed. I've also added an "egpio input" shell command.
>> Am 09.07.19 um 20:00 schrieb Michael Balzer:
>>> Thomas,
>>> there may be a bug in the max7317 component:
>>> uint8_t max7317::Input(uint8_t port)
>>> uint8_t* p = m_spibus->spi_cmd(m_spi, buf, 1, 1, port + 0x80);
>>> According to the max7317 specsheet the read operation needs a second (dummy) byte. So this should be…
>>> uint8_t* p = m_spibus->spi_cmd(m_spi, buf, 1, 2, port + 0x80, 0);
>>> Please try & report.
>>> Am 09.07.19 um 13:10 schrieb - -:
>>>> Hello,
>>>> How can I read inputs from max7317.
>>>> when I try to log ESP_LOGD(TAG,"EGPIO5 input: %d", MyPeripherals->m_max7317->Input(MAX7317_EGPIO_5));
>>>> i get allways 0 when i put the egpio pin to GND or 3.3v
>>>> do i somthing wrong or does it not work.
>>>> Regards Thomas
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190710/2d4d2159/attachment.html>
