[Ovmsdev] std::string data corruption (issue #189)
Wed Jan 30 16:41:29 HKT 2019
Mark,
issue #2892 mentions using only the lower 2 MB of SPI RAM as a workaround. Where are our allocations placed by the allocator? Does it fill from
the middle or end? If not we don't use the upper half yet.
A possible workaround for the most apparent issues with this (string assembly) could be to use char buffers instead of std::string. I was
thinking about doing that at least for the websocket stream.
But if this really is a hardware issue it can affect all objects in SPI RAM, appending to std::string then only triggers this more often.
Another workaround could be to run everything on core 0.
Am 30.01.19 um 03:33 schrieb Mark Webb-Johnson:
> Michael,
> Espressif’s response (and linking to that other issue) sounds like others are seeing this.
> Lousy timing (with Chinese New Year next week), so don’t expect anything quick from Espressif. I guess we’ll just have to live with it until
> they can find a workaround. It sounds like the issue is at the hardware level and a compiler patch will be needed.
>> On 30 Jan 2019, at 3:07 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>> → https://github.com/espressif/esp-idf/issues/3006
>> Am 28.01.19 um 20:46 schrieb Michael Balzer:
>>> To clarify: the bug is most likely not restricted to the case of building a message in a buffer. It can possibly cause corruptions in any
>>> RAM section, so can well be responsible for many/most of the unidentified crashes and stack/heap corruptions we're experiencing.
>>> Am 28.01.19 um 20:43 schrieb Michael Balzer:
>>>> For those not following the github discussion: I'm pretty sure I've nailed the bug down.
>>>> I have reproduced the bug in a simple test project and intend to raise an issue with Espressif on this.
>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#issuecomment-457965435
>>>> If you'd like to test this on your module, configure the project to your wifi credentials, then use "make flash". As the test project is
>>>> small, this normally will not erase your OVMS config partition, but a backup is always recommended.
>>>> Regards,
>>>> Michael
>>>> Am 24.01.19 um 21:19 schrieb Michael Balzer:
>>>>> Everyone please have a look at…
>>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#issuecomment-457334248
>>>>> Please try to reproduce the bug on your modules.
>>>>> I'm open for explanations.
>>>>> I thought this might be some copy-on-write bug with std::string, but the gcc 5.x libstdc++ does no longer use that implementation
>>>>> (wouldn't be C++11 compliant as well). I also tried moving all strings to temporary buffers, but modes 5 & 6 eliminated this explanation
>>>>> as well.
>>>>> My remaining theories:
>>>>> * A task writing out of bounds (but only 0-bytes?)
>>>>> * A hardware issue only affecting some modules
>>>>> A hardware issue only affecting some percentage of ESP32 could explain this as well as the strange heap corruptions that seem to affect
>>>>> some modules especially often.
>>>>> Regards,
>>>>> Michael
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190130/dba2259b/attachment.htm>
