[Ovmsdev] Reducing wifi/netmanager log messages
Thu Jan 17 22:08:39 HKT 2019
We’re up to 3.1.011-202-g3974d64, and looking good from my point of view. My javascript object code is in place, and working well. I’ve ported over a bunch of vehicle functions to OvmsVehicle object and they work well.
I see Steve committed another change to try to address this. I’ll run it in my car, but might take a while to see if it solves the problem or not.
Once we’ve got that stable, I think we are well overdue for a 3.1.012. Or maybe a 3.2.0 given the number of changes we have now?
> On 17 Jan 2019, at 5:33 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Steve,
> I'll try to find some time for a closer look this evening, but the error seems to be in there: I've reversed your commit yesterday for my module
> and it's working perfectly again today.
> My situation is standard (I believe…) of using wifi client mode at home and modem + wifi ap on the road. My wifi mode is apclient, using my
> phone for the dashboard on the road.
> Am 17.01.19 um 00:44 schrieb Stephen Casner:
>> I'll change the implementation to more explicit checks.
>> -- Steve
>> On Wed, 16 Jan 2019, Stephen Casner wrote:
>>> Michael,
>>> I thought that skipping the netif_set_default() and > SetDNSServer()
>>> calls would be OK there because they should be called when the
>>> priority interface (pri) changes. This worked for me. It was a
>>> simplification to avoid having to make a separe check inside the DNS
>>> code to suppress its messages when DNS did not change.
>>> Now, I admit that comparing interface object addresses could give a
>>> false result if the objects come and go, but again I thought that did
>>> not happen here. Do you know why this would be different for your
>>> situation compared to mine?
>>> -- Steve
>>> On Wed, 16 Jan 2019, Michael Balzer wrote:
>>>> Steve,
>>>> I think you broke something, I'm now losing connectivity after changing from wifi to modem or back.
>>>> On a first quick glance, your change on OvmsNetManager::PrioritiseAndIndicate() looks suspicious to me, as the return skips the netif_set_default() and
>>>> SetDNSServer() calls.
>>>> Regards,
>>>> Michael
