[Ovmsdev] Android App v3.12.2 in Play Store
Fri Jan 11 10:01:17 HKT 2019
Geir,
I haven’t had time to do anything on the iOS App at all. I did try to get it running on the latest xcode, but many (hundreds of) error messages and a real PITA. Just too much on my plate at the moment to work on it.
There are a bunch of drop-in iOS framework libraries for chat bubble style messaging. I think the UI would be easy.
> On 11 Jan 2019, at 4:48 AM, Geir Øyvind Vælidalo <geir at validalo.net> wrote:
> Mark,
> Did you get anywhere with the message-function on iOS-App? Would it be possible to send commands like «stat» and then see the result in the App?
> Geir
>> 3. jan. 2018 kl. 13:32 skrev Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>:
>> Geir,
>> I’m looking after the iOS version. I can build and release for Apple devices, and post updates to iTunes Store.
>> I have some changes made to enlarge some fields, and I want to add a ‘messages’ function similar to the Android version (to be able to issue commands to both v2 and v3 boxes). Other than that, I don’t have anything outstanding on the iOS version - it seems to support the v3 metrics just fine as is.
>> If anybody else has any changes to iOS version, please make a pull request on the GitHub and I’ll merge in.
>> Regards, Mark
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190111/2717de1c/attachment.htm>
