[Ovmsdev] github usability work
Sun Jan 6 20:11:47 HKT 2019
First draft of a project structure is done:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/projects
Am 06.01.19 um 11:33 schrieb Robert Sharpe (Electric Vehicle Consultant):
> Thanks - looks good.
> --- On Sun, 06 Jan 2019 09:54:03 +0000 *Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>>* wrote ----
>     I've added the labels, and I think using "Projects" for the subsystems and car adaptions work makes sense.
>     I'll give that a try, it seems that's just an optional additional structuring that can be removed if not appropriate.
>     Regards,
>     Michael
>     Am 06.01.19 um 10:16 schrieb Robert Sharpe (Electric Vehicle Consultant):
>     Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>     Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
>     _______________________________________________
>     OvmsDev mailing list
>     OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
>     http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>         Hi Mark,
>         I wanted to tidy up new issues created related to the usability work I am doing.  But cant seem to create or apply labels.
>         Could you apply the labels "enhanced" and "help wanted" to the following
>         30kwh Leaf max gids needs to be set manually <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/181>
>         #181 opened 7 days ago by arsharpe <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues?q=is%3Aissue+is%3Aopen+author%3Aarsharpe>
>         Leaf model year needs to be set manually <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/180>
>         #180 opened 7 days ago by arsharpe <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues?q=is%3Aissue+is%3Aopen+author%3Aarsharpe>
>         Also it would be good to categorise issues associated with this work.  How do you suggest we do that eg using a "Label" or "Project"
>         Rob
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190106/be91a8ca/attachment.htm>
