[Ovmsdev] std::string data corruption (issue #189)
Wed Jan 30 03:07:40 HKT 2019
→ https://github.com/espressif/esp-idf/issues/3006
Am 28.01.19 um 20:46 schrieb Michael Balzer:
> To clarify: the bug is most likely not restricted to the case of building a message in a buffer. It can possibly cause corruptions in any RAM section, so can
> well be responsible for many/most of the unidentified crashes and stack/heap corruptions we're experiencing.
> Am 28.01.19 um 20:43 schrieb Michael Balzer:
>> For those not following the github discussion: I'm pretty sure I've nailed the bug down.
>> I have reproduced the bug in a simple test project and intend to raise an issue with Espressif on this.
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#issuecomment-457965435
>> If you'd like to test this on your module, configure the project to your wifi credentials, then use "make flash". As the test project is small, this normally
>> will not erase your OVMS config partition, but a backup is always recommended.
>> Am 24.01.19 um 21:19 schrieb Michael Balzer:
>>> Everyone please have a look at…
>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#issuecomment-457334248
>>> Please try to reproduce the bug on your modules.
>>> I'm open for explanations.
>>> I thought this might be some copy-on-write bug with std::string, but the gcc 5.x libstdc++ does no longer use that implementation (wouldn't be C++11
>>> compliant as well). I also tried moving all strings to temporary buffers, but modes 5 & 6 eliminated this explanation as well.
>>> My remaining theories:
>>> * A task writing out of bounds (but only 0-bytes?)
>>> * A hardware issue only affecting some modules
>>> A hardware issue only affecting some percentage of ESP32 could explain this as well as the strange heap corruptions that seem to affect some modules
>>> especially often.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190129/71eb5176/attachment-0001.html>
