[Ovmsdev] std::string data corruption (issue #189)
Tue Jan 29 03:46:58 HKT 2019
To clarify: the bug is most likely not restricted to the case of building a message in a buffer. It can possibly cause corruptions in any RAM section, so can
well be responsible for many/most of the unidentified crashes and stack/heap corruptions we're experiencing.
Am 28.01.19 um 20:43 schrieb Michael Balzer:
> For those not following the github discussion: I'm pretty sure I've nailed the bug down.
> I have reproduced the bug in a simple test project and intend to raise an issue with Espressif on this.
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#issuecomment-457965435
> If you'd like to test this on your module, configure the project to your wifi credentials, then use "make flash". As the test project is small, this normally
> will not erase your OVMS config partition, but a backup is always recommended.
> Am 24.01.19 um 21:19 schrieb Michael Balzer:
>> Everyone please have a look at…
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#issuecomment-457334248
>> Please try to reproduce the bug on your modules.
>> I'm open for explanations.
>> I thought this might be some copy-on-write bug with std::string, but the gcc 5.x libstdc++ does no longer use that implementation (wouldn't be C++11
>> compliant as well). I also tried moving all strings to temporary buffers, but modes 5 & 6 eliminated this explanation as well.
>> My remaining theories:
>> * A task writing out of bounds (but only 0-bytes?)
>> * A hardware issue only affecting some modules
>> A hardware issue only affecting some percentage of ESP32 could explain this as well as the strange heap corruptions that seem to affect some modules
>> especially often.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190128/5613e3b6/attachment.html>
