[Ovmsdev] Reducing wifi/netmanager log messages
Fri Jan 18 22:07:09 HKT 2019
Thanks Steve, the fix works.
Am 18.01.19 um 08:18 schrieb Stephen Casner:
> Mark,
> To be clear, the change I committed should fix the problem for Michael
> that my earlier commit introduced, but this is not a fix for the weak
> wifi performance nor the wifi getting stuck.  This change only avoids
> repeated log messages every 10 seconds when the wifi client is out of
> range of any AP.  You can observe that right away by just driving away
> from your AP.
> I have now implemented the changes to ovms_location to support adding
> action parameters to the location configuration.  I have not committed
> it yet, though, because there's no code yet to make those actions
> effective.
> On Thu, 17 Jan 2019, Mark Webb-Johnson wrote:
>> We're up to 3.1.011-202-g3974d64, and looking good from my point of view. My javascript object code is in place, and working well. I've ported over a bunch of vehicle functions to OvmsVehicle object and they work well.
>> I see Steve committed another change to try to address this. I'll run it in my car, but might take a while to see if it solves the problem or not.
>> Once we've got that stable, I think we are well overdue for a 3.1.012. Or maybe a 3.2.0 given the number of changes we have now?
>>> On 17 Jan 2019, at 5:33 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>> Steve,
>>> I'll try to find some time for a closer look this evening, but the error seems to be in there: I've reversed your commit yesterday for my module
>>> and it's working perfectly again today.
>>> My situation is standard (I believe...) of using wifi client mode at home and modem + wifi ap on the road. My wifi mode is apclient, using my
>>> phone for the dashboard on the road.
>>> Am 17.01.19 um 00:44 schrieb Stephen Casner:
>>>> I'll change the implementation to more explicit checks.
>>>>                                                        -- Steve
>>>> On Wed, 16 Jan 2019, Stephen Casner wrote:
>>>>> Michael,
>>>>> I thought that skipping the netif_set_default() and > SetDNSServer()
>>>>> calls would be OK there because they should be called when the
>>>>> priority interface (pri) changes.  This worked for me.  It was a
>>>>> simplification to avoid having to make a separe check inside the DNS
>>>>> code to suppress its messages when DNS did not change.
>>>>> Now, I admit that comparing interface object addresses could give a
>>>>> false result if the objects come and go, but again I thought that did
>>>>> not happen here.  Do you know why this would be different for your
>>>>> situation compared to mine?
>>>>>                                                        -- Steve
>>>>> On Wed, 16 Jan 2019, Michael Balzer wrote:
>>>>>> Steve,
>>>>>> I think you broke something, I'm now losing connectivity after changing from wifi to modem or back.
>>>>>> On a first quick glance, your change on OvmsNetManager::PrioritiseAndIndicate() looks suspicious to me, as the return skips the netif_set_default() and
>>>>>> SetDNSServer() calls.
>>>>>> Regards,
>>>>>> Michael
>>>> OvmsDev mailing list
