[Ovmsdev] Reducing wifi/netmanager log messages
Fri Jan 18 00:38:30 HKT 2019
Michael,
I already committed a more robust implementation that only skips log
messages and no other steps.  No need to investigate the previous
behavior, just go ahead and update.
On Thu, 17 Jan 2019, Michael Balzer wrote:
> Steve,
> I'll try to find some time for a closer look this evening, but the error seems to be in there: I've reversed your commit yesterday for my module
> and it's working perfectly again today.
> My situation is standard (I believe...) of using wifi client mode at home and modem + wifi ap on the road. My wifi mode is apclient, using my
> phone for the dashboard on the road.
> Am 17.01.19 um 00:44 schrieb Stephen Casner:
> > I'll change the implementation to more explicit checks.
> >                                                         -- Steve
> > On Wed, 16 Jan 2019, Stephen Casner wrote:
> >> Michael,
> >> I thought that skipping the netif_set_default() and > SetDNSServer()
> >> calls would be OK there because they should be called when the
> >> priority interface (pri) changes.  This worked for me.  It was a
> >> simplification to avoid having to make a separe check inside the DNS
> >> code to suppress its messages when DNS did not change.
> >> Now, I admit that comparing interface object addresses could give a
> >> false result if the objects come and go, but again I thought that did
> >> not happen here.  Do you know why this would be different for your
> >> situation compared to mine?
> >>                                                         -- Steve
> >> On Wed, 16 Jan 2019, Michael Balzer wrote:
> >>> Steve,
> >>> I think you broke something, I'm now losing connectivity after changing from wifi to modem or back.
> >>> On a first quick glance, your change on OvmsNetManager::PrioritiseAndIndicate() looks suspicious to me, as the return skips the netif_set_default() and
> >>> SetDNSServer() calls.
> >>> Regards,
> >>> Michael
> > OvmsDev mailing list
