[Ovmsdev] Reducing wifi/netmanager log messages
Thu Jan 17 07:32:38 HKT 2019
Maybe expressif/esp-idf vs openvehicles/esp-idf?
On Wed, 16 Jan 2019, Stephen Casner wrote:
> Michael,
> I thought that skipping the netif_set_default() and > SetDNSServer()
> calls would be OK there because they should be called when the
> priority interface (pri) changes.  This worked for me.  It was a
> simplification to avoid having to make a separe check inside the DNS
> code to suppress its messages when DNS did not change.
> Now, I admit that comparing interface object addresses could give a
> false result if the objects come and go, but again I thought that did
> not happen here.  Do you know why this would be different for your
> situation compared to mine?
> On Wed, 16 Jan 2019, Michael Balzer wrote:
> > Steve,
> > I think you broke something, I'm now losing connectivity after changing from wifi to modem or back.
> > On a first quick glance, your change on OvmsNetManager::PrioritiseAndIndicate() looks suspicious to me, as the return skips the netif_set_default() and
> > SetDNSServer() calls.
> > Regards,
> > Michael
