[Ovmsdev] Android App v3.12.2 in Play Store
Geir Øyvind Vælidalo
geir at validalo.net
Fri Jan 11 16:12:31 HKT 2019
Hi Mark,
I totally know what you mean. The changes from Xcode 9.4 to 10 are major. I had to change the build system to «legacy build system» to get the OVMS APP to compile. Unfortunately that is a temporary solution.
I wish I was more fluent in Xcode...
Geir
> 11. jan. 2019 kl. 03:01 skrev Mark Webb-Johnson <mark at webb-johnson.net>:
> Geir,
> I haven’t had time to do anything on the iOS App at all. I did try to get it running on the latest xcode, but many (hundreds of) error messages and a real PITA. Just too much on my plate at the moment to work on it.
> There are a bunch of drop-in iOS framework libraries for chat bubble style messaging. I think the UI would be easy.
>> On 11 Jan 2019, at 4:48 AM, Geir Øyvind Vælidalo <geir at validalo.net <mailto:geir at validalo.net>> wrote:
>> Mark,
>> Did you get anywhere with the message-function on iOS-App? Would it be possible to send commands like «stat» and then see the result in the App?
>> Geir
>>> 3. jan. 2018 kl. 13:32 skrev Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>:
>>> Geir,
>>> I’m looking after the iOS version. I can build and release for Apple devices, and post updates to iTunes Store.
>>> I have some changes made to enlarge some fields, and I want to add a ‘messages’ function similar to the Android version (to be able to issue commands to both v2 and v3 boxes). Other than that, I don’t have anything outstanding on the iOS version - it seems to support the v3 metrics just fine as is.
>>> If anybody else has any changes to iOS version, please make a pull request on the GitHub and I’ll merge in.
>>> Regards, Mark
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190111/70a82fc2/attachment.html>
