[Ovmsdev] How can I help
Tue Jan 8 13:44:57 HKT 2019
I think the advanced user definition maybe too restrictive.
Our current user base is perhaps best described as:
A science-based hobbyist (electronics, computers, etc)
Able to work with computers and electronics
Understands the core underlying technology
A not-so-capable user can still use our system, but requires someone with the above capabilities to help setup and provide local support.
> On 5 Jan 2019, at 2:05 AM, Robert Sharpe (Electric Vehicle Consultant) <robert.sharpe at evergreen-consulting.co.uk> wrote:
> Hi Michael,
> Thanks for your excellent points.
> In terms of suggested actions does the following accurately summarise your thoughts (with redline changes) summary?
> User Definition
> a general household DIY capable person.
> can mount and plug things into the vehicle
> will only read
> a single quick install sheet
> a list of text commands
> maybe 3 min youTube videos
> cant
> create connectors/leads
> modify the OVMS hardware
> don't know about internal or technical terms, such as Nissan Leaf GIDs, WiFi SSID, etc
> User Expectations
> the unit fully supports the listed features under all reasonable conditions
> reliable in operation
> error messages are non-technical and help the user solve the problem
> should be plug-n-play where possible, eg
> automatically detects vehicle type and year
> automatically detects battery capacity, etc
> Rename User Manual to "Advanced User Manual"
> Advanced User Definition
> can
> modify the OVMS hardware (eg add wake-up hardware)
> modifying car at module level (eg remove TCU on Leaf)
> knows internal or technical terms, such as Nissan Leaf GIDs, WiFi SSID, etc
> Advanced User Expectations
> to easily access detailed reasons why a feature doesn't work and possible workarounds
> Rob
> --- On Fri, 04 Jan 2019 14:13:43 +0000 Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote ----
> Rob,
> maybe I'm too pessimistic (realistic?), but if you're targeting users within that category, your spec lacks "doesn't like reading manuals or searching the web for answers" and "likes watching short videos", so working on the manual with these users in mind is futile.
> My last App support: the App told the user it can't connect to the server, he should verify the server address and vehicle ID. I sent him the data he should use. He insisted in having entered exactly that. After four or five mails I finally got him to send me this "screenshot":
> <1.jpg>
> Many current users (even v2 users) I have supported fit into that category, none of them would (could) read anything longer than a few sentences. The manual introduction section is already too much for them, they normally just jump into using the system and they normally fail at things like entering a server name or password correctly.
> Of course we should generally try to further simplify the UIs, e.g. provide a select option for the standard servers and an account registration API.
> But the manual IMO is meant for the capable / advanced user trying to get specific jobs done with the system.
> For the "low end" user target, a single (!) page "first setup" sheet is needed, and a series of 3 minute feature introduction videos on Youtube.
> Am 03.01.19 um 16:05 schrieb Robert Sharpe (Electric Vehicle Consultant):
> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
> Hi Mark/All,
> Sometime ago I did lots of obvious updates of the User Manual to help readability, etc as a first stab.
> Now doing a second stab, there is one thing that has come to light and that is the definition of a user.
> In order to check the documentation I need to know what the user is capable of off. I appreciate that the definition of user has probably changed over the development of the project and the product has matured enough that it can be operated by non-technical users opening up its usefulness.
> Assuming that what were the original users would how fall into the category of Developers, does the following draft specification accurately reflect the minimum capabilities of a current/future User?
> User Definition
> cant
> User Expectations
> Please let me know if this is accurate or what changes/clarifications need to be made.
> Rob
> --- On Tue, 07 Aug 2018 03:30:33 +0100 Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote ----
> Robert,
> Thanks for the offer to help out.
> Perhaps you can look at it from the user’s point of view, and try to improve our documentation and approach for that?
> On 3 Aug 2018, at 4:01 PM, Robert Sharpe (Electric Vehicle Consultant) <robert.sharpe at evergreen-consulting.co.uk <mailto:robert.sharpe at evergreen-consulting.co.uk>> wrote:
> Hi All,
> I like where OVMS project is going and would like to help if I can.
> Where I can possibly add value is
> make things easy for people to use (eg documentation, etc)
> experienced on UI/UX design, etc.
> as an ex developer, good at testing and finding problems.
> Some initial thoughts on activities are
> to make it easier for non technical people to use OVMS, help doc author pull out user only specific content to a user manual and make it non-technical (renaming current user manual to developers manual)
> to help people see roadmap, provide a mechanism to see who wants what and who is working on it.
> to allow developers and users to display problems with their vehicle only, add Labels to the github issues list or group by project (I am not an expert on GITHUB so please be patient)
> update GITHUB readmes to better direct people that find GITHUB first.
> Please
> let me know if anyone is dealing with any of these areas
> add and/or vote for what things you think I can help with by putting a comment next to the activity above.
> Robert Sharpe
> 07711 252971
> <1.gif> <http://www.linkedin.com/in/arsharpe> <2.gif> <http://www.twitter.com/EgcTechnical> <3.gif> <https://www.facebook.com/EvergreenConsultingLtd> <4.gif> <http://www.evergreen-consulting.co.uk/staff/skype/rsharpe.html> <5.gif> <http://www.evergreen-consulting.co.uk/staff/calendars/rsharpe.html?utm_campaign=General&utm_source=EmailFooter&utm_medium=Email>
> <6.png> <http://www.evergreen-consulting.co.uk/?utm_campaign=General&utm_source=EmailFooter&utm_medium=Email>
> Your Plugged-in Partner
> Evergreen Consulting is the trading name of Sharpe Consultants Ltd
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190108/d778bb47/attachment-0001.html>
