[Ovmsdev] Battery capacity metrics (for the Leaf, and in general)
Robin O'Leary
ovmsdev at caederus.org
Sun Feb 24 21:08:07 HKT 2019
On Sun, Feb 24, 2019 at 05:34:21AM +0000, Anko Hanse wrote:
> I had been searching for a way to directly get the battery capacity from
> the can bus, but had not found one. Hence my search for alternatives
> via the VIN.
> Even if I do a google now on 'leaf can bus 59e' I don't get useful
> hits. And no finds in the canmsgs google docs either... Makes me
> wonder what docs you have access to...
I have no documentation; everything is speculation, based on many forum
discussions and my own observations of the car I own (a 2015 UK-built
24kWh Acenta), so it is quite possible that my conclusions are wrong,
or don't apply to other models. I would like others to check whether
the value in 0x59e is a useful measure of capacity for them before we
adopt it as a standard.
> As for the web-interface, we might want to still display the detected
> battery capacity there, just not as a changeable setting but as
> readonly info.
Yes, although these are two different things, which may both be useful
for different purposes. Unlike the fixed value of max_gids, the battery
energy capacity metric varies over time: as well as a general decrease
due to battery age, it also has short-term up and down swings as the BMS
recalibrates after charging. Some people don't like this "randomness",
and prefer to see calculations relative to a fixed base-line. There is
something to be said for both approaches.
As for the config page, for now, I would suggest structuring it so that
the switches for the preferred SOC and SOH display metrics are paired
with conditional settings for the corresponding full-scale value, maybe
something like:
SOC display: {xnl.soc.newcar}
. (*) from dashboard display {=false}
. ( ) relative to fixed value: {=true}
. . [ ] (GID=80kWh) {xnl.maxGids}
SOH display: {xnl.soh.newcar}
. . [ ] (amp.hour) {xnl.newCarAh}
Desc: Digital signature
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190224/2cd12dc6/attachment-0002.sig>
