[Ovmsdev] RETOOLS web
Robert Cotran
robert at cotran.ca
Thu Feb 14 00:15:54 HKT 2019
Geir,
I tried emailing you directly, didn't work -- can you send me your
latest email address at robert at cotran.ca?
Thanks!
Rob
On 2019-02-13 10:40 AM, Geir Øyvind Vælidalo wrote:
> Great idea! Someone please make this soon, as I just got my new Kia
> e-Niro 🙂 Need to do some work on the e-Niro-support.
> Geir
>> 13. feb. 2019 kl. 13:05 skrev Mark Webb-Johnson
>> <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>:
>> Michael, this is probably for you - but if anybody else can help
>> please do…
>> I am trying to see how hard it would be to do a web based interface
>> to the RETOOLS system. Presumably this would appear in the menu as
>> Tools / Reverse Engineering (or some such abbreviation if that is too
>> long). The basic screen would look something like this:
>> | | | | hdr1 | hdr2 | hdr3 |
>> hdr4 | | | |
>> | | Controls | | | | | | | Info
>> | | | | col1 | col2 | col3 |
>> col4 | | | |
>> | | Status | | | | | | |
>> | | | | | | TABLE |
>> | | | | | | | | | Extra
>> The controls are just a set of controls - things that bring up
>> dialogs for more information or perform actions. Like start/stop RE,
>> switch modes, manipulate DBC files, etc. Left justified in the frame,
>> and perhaps 10% of the width. Height can dynamically adjust with the
>> text content.
>> The Status, Info, and Extra panes are just a dynamically updated text
>> panes. Main code needs to be able to send text here and have it shown
>> in the appropriate pane. Right justified in the frame and perhaps 30%
>> of the width. Height can dynamically adjust with the text content.
>> The TABLE is a table. Probably 5 columns by many rows (anywhere from
>> 20 to 200 or so). Either paged, scrolling, or just very tall. Paged
>> is probably preferable. Would need a simple mechanism to dynamically
>> add/update a row (identified by ‘key’ column and in sorted order),
>> presumably using the web socket. Also need something to be able to
>> dynamically clear the entire table. The RETOOLS code would use this
>> to update the table in realtime (presumably over a web socket). It
>> would be good if the table could do things like search filtering of
>> displayed rows, column sorting, etc (all client side - something like
>> datatables.net <http://datatables.net/>).
>> For example, look at this output:
>> OVMS# re dbc list
>> key records ms last
>> can1/100:0081 2 22000 01 02 03 04 05 | .....
>> can1/101 1 44000 01 02 03 04 | ....
>> dbc/DI_Signal1: 129 km
>> dbc/DI_Signal2: 1 km
>> dbc/DI_Signal3: 130 kWh
>> dbc/DI_Signal4: 122 Degrees
>> The idea is to be able to show the key, records, ms, last, and ascii
>> dump in the main table. Then, clicking on a row would show the
>> statistics for that message in the Info pane, and DBC signals in the
>> Extra pane.
>> I can handle the RETOOLS side, but the javascript is beyond me. I
>> also had a look at the ovms web server framework, but it doesn’t seem
>> to be able to do the table part (yet)?
>> Any idea how complex this is?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190213/99d2cd78/attachment-0001.html>
